PW80 ignition problem
Nunk
PostPosted: 02:38 - 02 Jun 2018    Post subject: PW80 ignition problem Reply with quote
My 2007 Yamaha PW80 will not kick start. Checking of the electrical components reveals:
Spark plug - OK ( tested on another bike)
CDI - not checked (how to?)
Ignition Coil - Primary 0.32 ohms ( Spec 0.32-0.48); Secondary 11.9kohms (Spec 5.7-8.2);
Stator coil 165 ohms (Spec 200-300).
Obviously both the ignition coil secondary and the stator coil are out of spec. BUT, significantly so??
With the plug removed and earthed, turning over the engine (counter-clockwise) using a variable speed electric drill on the rotor nut reveals a spark just appearing at 1900rpm and progressively getting stronger up to 3900rpm (max drill speed).
Does the described behaviour point to which of the components (CDI, ignition coil, stator coil) may be at fault?
Tankie
PostPosted: 08:36 - 02 Jun 2018    Post subject: Reply with quote
Stator coil (low speed) winding failure. Replace or rewind, but just disconnect the kill wire B/W first to double check as the switch might be short
jaffa90
PostPosted: 15:37 - 02 Jun 2018    Post subject: Reply with quote
""""""With the plug removed and earthed, turning over the engine (counter-clockwise) using a variable speed electric drill on the rotor nut reveals a spark just appearing at 1900rpm and progressively getting stronger up to 3900rpm (max drill speed). """"""
Any spark when kick starting??
Nunk
PostPosted: 06:09 - 05 Jun 2018    Post subject: Reply with quote
1. Switch OK and disconnected for these tests.
2. Kicking over irregularly produces a spark such as this sequence: S,0,0,0,S,S,0,0,0,0,0,S,S,S,0,0,0,0,S,S,0,0,0,0,S (S=spark; 0=no spark). The S intensity will vary through the sequence.
If i get a continuous sequence of medium to strong sparking, I'll replace the plug back in the engine and pray. Sometimes the engine will start but more often won't.
Now if I just had another running PW80 I could swap components and hopefully find the culprit. No such luxury unfortunately so I'm trying to pin it down to the most likely component before going on a spending spree.
jaffa90
PostPosted: 10:06 - 05 Jun 2018    Post subject: Reply with quote
As said (Tankie). Find a way to check the Stator coil (Magneto) output and the ignition coil input.
bypass2
PostPosted: 23:19 - 05 Jun 2018    Post subject: Reply with quote
just a guess maybe the the woodruff key is worn/damaged
Nunk
PostPosted: 11:41 - 11 Jun 2018    Post subject: Reply with quote
1. Woodruff key is in perfect condition.
2. With all electrics hooked up, attempting kick starting results in 20-25VAC only from the stator coil. I would be expecting 50V minimum from the stator coil under attempted kick starting. Would anyone care to comment on my expectation??
I've now ordered a new stator coil and CDI. Coil is next if these replacement parts don't solve the problem.
Nunk
PostPosted: 11:33 - 19 Jul 2018    Post subject: Reply with quote
Well the new stator coil finally arrived. It checked out at 245 ohms which is mid spec. Installed it and now have strong spark and machine starts first kick. Excellent result.
However, I found that the machine didn't display any further response past half throttle. So, long story short, I removed the front panel with filter element from the air filter box and found I now had good response up to full throttle. Removed the filter element, replaced front panel and bike reverted to previous problem. Conclusion - lack of sufficient air intake and no restriction from filter element.
Drilled three half inch holes in each side of the air filter box (new incoming air stiill passes through filter element).
Now I have a much improved performing machine. I may just try a 130 main jet (125 standard currently installed) to see if it is advantageous.
Tankie
PostPosted: 13:04 - 19 Jul 2018    Post subject: Reply with quote
Just check your plug colour
Tankie
PostPosted: 16:53 - 19 Jul 2018    Post subject: Reply with quote
The last post was made 5 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 17 - Page Size: 64.27 Kb
