GSX750F running problem
GavintheTazma...
PostPosted: 00:11 - 03 Jun 2018    Post subject: GSX750F running problem Reply with quote
I have a 1998 gsxf750 which wont run properly. It will tick over on idle forever in the year but when you put it under load, no2 cylinder dies and runs on the other 3 cylinders. I have had the plugs and coils changed, swapped the plugs around but still drops out on cylinder 2. I have had the electrics looked at and all the cables and earths are good, and all the ohms readings are within limits. both my self and my mechanic cannot work out whats causing the fault, I`m thinking ECU but not sure, so any info on this would be gratefully received.
jaffa90
PostPosted: 00:28 - 03 Jun 2018    Post subject: Reply with quote
Carbs or fuel injection?
How do you know no2 dies?
What about the valve clearances ?
temeluchus
PostPosted: 01:13 - 03 Jun 2018    Post subject: Reply with quote
Probably a stuck float or some obstruction in the float valve.
Before you go pulling the carbs off, try draining the contents of carb 2 into a clear glass and see if its full of cack.
GavintheTazma...
Its carbs, the valve clearances have been done, and the exhaust pipe on no2 cyclinder is cold when the others are warm/hot.
temeluchus
PostPosted: 01:16 - 03 Jun 2018    Post subject: Reply with quote
Isn't that what I just said? Wink
GavintheTazma...
temeluchus: the carbs have been checked and cleaned. float heights are correct and new fuel been added.
temeluchus
PostPosted: 01:52 - 03 Jun 2018    Post subject: Reply with quote
misread the first bit of your line.
It probably wont be the ignitor box as that would kill two cylinders if it wasnt firing a coil.
Could be an air leak, is the balancing spigot plugged? Inlet or airbox rubbers ok?
Did you replace the float valve? These cause a fair bit of trouble on Mikuni carbs.
If the carbs and ignition are 100% then something in the engine is worn or broken.
bypass2
PostPosted: 23:00 - 03 Jun 2018    Post subject: Reply with quote
Maybe the slide diaphragm split/damaged. have you put the plug on the head to see if it does spark
jaffa90
PostPosted: 00:30 - 04 Jun 2018    Post subject: Reply with quote
As said (bypass2), do the carb slides all work?
temeluchus
PostPosted: 03:59 - 06 Jun 2018    Post subject: Reply with quote
if the diaphragm split the exhaust wouldn’t be cold,
as fuel from the main jet would still be making it to the cylinder, but that cylinder would just be strangled compared to the others.
jaffa90
PostPosted: 09:37 - 06 Jun 2018    Post subject: Reply with quote
""""It will tick over on idle forever in the year """
"""" the exhaust pipe on no2 cyclinder is cold when the others are warm/hot."""
Just a bit confusing!!!!!
PostPosted: 18:17 - 09 Jun 2018    Post subject: Reply with quote
By whom?
GavintheTazma...
PostPosted: 18:30 - 12 Jun 2018    Post subject: Reply with quote
Jaffa90: That is what I cant make out, why it ticks over all day long but put it under load and No2 cylinder drops out.
A100man: By a competent mechanic who races bikes.
Bypass2: all carb diaphragms have been replaced with new ones.
I have had all the plugs out and they all spark against the head, I`m at a loss as to what is causing this fault.
jaffa90
PostPosted: 21:37 - 12 Jun 2018    Post subject: Reply with quote
Is it ticking over on 3 cylinders only?????????????????????
PostPosted: 21:43 - 12 Jun 2018    Post subject: Reply with quote
Have you tried altering the position of no2 to, say, position no. 1 in the bank and seeing if the problem follows it?
PostPosted: 13:17 - 13 Jun 2018    Post subject: Reply with quote
You're assuming two things 1) he/she is infallible 2) nothing has happened since.
The last post was made 5 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 17 - Page Size: 89.49 Kb
