ybr125 |
ybr125 L Plate Warrior
wr6133 |
wr6133 World Chat Champion
ybr125 |
Posted: 22:07 - 05 Jun 2018 Post subject: |
wish I knew where you were seeing them for that price
theres one for £45
I was after an answer to the question though really
cheers. |
Evil Hans |
Evil Hans World Chat Champion
WmY |
WmY Renault 5 Driver
Posted: 00:08 - 06 Jun 2018 Post subject: |
Hm, it's a steel swinging arm, and there's a shock absorber on both sides, isn't there? What'll they charge to weld it? If it's a lot cheaper than a new swinging arm, I'd go for it, if there's only a tenner in it, no. After all, the sections are welded together anyway.... It also depends how good at tube welding your man is.
How long do you reckon it's been cracked for
Edit: Wow, Evil Hans, bargain! (if not cracked...). |
ybr125 |
arry |
arry Super Spammer
ybr125 |
Rogerborg |
Rogerborg nimbA
Posted: 09:25 - 06 Jun 2018 Post subject: |
It sound like the only answer you're going to accept is "Yes, they can be welded and you should pay £150 to a random subcontractor to do it."
£150 + VAT, perchance?
Your current swing arm is 9 years old. There's no need to replace it with a new one. I'd bag the arm + wheel on eBay for £90 delivered, after first checking that I could get the swing arm bolt out of the existing one.
If you can't then it might turn into a pig of a job, and welding it in situ may be the best answer. ____________________ Biking is 1/20th as dangerous as horse riding.
ybr125 |
HappyDays |
HappyDays Renault 5 Driver
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 21:25 - 06 Jun 2018 Post subject: |
technically welding is bringing two bits of metal to moloten temperature and fusing whilst they are molten to create a single homogeneous artifact with no discontiniuity through the metal accross the joint, so it aught 'in theory' be as strong as if it had been made as one bit.
If sleeved.... suggests not welding but brazing... using a splint of metal inside the tube, and gluing it there with molten metal of a different kind... which isnt so strong, and personally I'm not that fond of...
However practically, it ALL comes down to who does the job, and how well.
doing a swing arm in-situ.. I would be rather sanguine they could weld up a crack, without getting the arm hot enough to melt the bushes it swings on... if they did manage it.. and using MIG these days is much more precice, but still... I would be worried that with necessary heat the bushes would be shot, without the joint wouldn't be properly made.
either way, I would want to take the swain arm off, and expect to replace bushes.... as if they were the cause of fail to start with, not tackling them you'll only be back where you are now in a couple of weeks.....
At that point, state of bushes and hassle removing old and fitting new, and likely state of the swing arm... as in how thin metal has rusted would have me deliberating and in that job, cost and time to weld would be but small part of the all-in deal.
Most expedient and cost effective, would likely be a 2nd hand swinger, 'complete' from a breaker, with bushes and pivot pin; bolt off, maybe assisted by hack-saw, bolt-on, job-jobbed, I'd expect to be able to do it in a lazy afternoon on my patio with no more tools than a halfords socket set and pound-shop hack-saw.
A new pivot pin and the shock-absorber grommets may be a wise investment whilst you have bits in pieces, but otherwise, I'd not be in too much of a hurry to try 'salvage' a busted swing-arm on a bike that common and new... maybe a different story on something old and rare like say a 1962 Greeves or DOT, but not on a YBR where bits is on the shelf new or used, even though I could.
As suggested, prices of used swing-arms are not that exhorbitant, and even with new pin and grommets you are likely to get a better job for less money than even unknown cheapo welding subby. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
ybr125 |
WmY |
ybr125 |
WmY |
Evil Hans |
Rogerborg |
Rogerborg nimbA
Posted: 13:18 - 07 Jun 2018 Post subject: |
Either you'd already told him to go ahead and do the work, in which case why did you ask?
Or you hadn't, in which case you should be naming and shaming and never, ever going there again. ____________________ Biking is 1/20th as dangerous as horse riding.
ybr125 |
arry |
arry Super Spammer
WmY |
Rogerborg |
Rogerborg nimbA
The last post was made 5 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
