Callumrayb |
Callumrayb Derestricted Danger
Posted: 13:37 - 06 Jun 2018 Post subject: Zontes firefly 125i cutting out |
Hello there, my recently bought zontes firefly 125i is cutting out of I rev it, warming it up for 30 minutes before each ride usually fixes the issue but it seems to be getting worse and worse. As I get to a traffic light and clutch while changing down gears it simply cuts out and won't yurn over until I switch it off for 5 seconds. Very frustrating. Any help or advice would be appreciated!
Another thing, does anyone know what this valve is?
https://imgur.com/HJVooDL ____________________ Hiiii |
WmY |
WmY Renault 5 Driver
Rogerborg |
Rogerborg nimbA
Posted: 14:06 - 06 Jun 2018 Post subject: |
Yup, that's a fuel tap, leading down to a fuel filter, possibly aftermarket. I'm guessing that this bike has been pre-abused by another owner?
From the fuel tap, I'd also guess that it's an older carb model rather than the new fuel injected one.
If so, what, if anything, are you doing with the choke when you start up and ride off? ____________________ Biking is 1/20th as dangerous as horse riding.
Callumrayb |
Rogerborg |
Rogerborg nimbA
Posted: 14:21 - 06 Jun 2018 Post subject: |
Urgh. If it's EFI then it could be just about anything. Tap, filter, hose, pump, injector, temperature sensor (if it has one), lambda sensor (if it has one), throttle position sensor, all or none of the above.
I'd be checking that all electrical connections are secure, then (no joke) looking for an OBD socket if it's a Euro4-bollocks compliant bike. ____________________ Biking is 1/20th as dangerous as horse riding.
Callumrayb |
The last post was made 5 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
