B5234FT |
B5234FT Brolly Dolly
Posted: 15:50 - 08 Jun 2018 Post subject: |
I'd suggest you probably don't need to. Those trochoidal pumps generally either work or they don't.
If you look through the sight glass and press the starter, you should see the oil level drop pretty much as soon as you push the starter button. Thereby confirming your oil pump is by and large working.
The red oil pressure light on the dash IS on a pressure switch on the GPZ500 (it's a level switch on some makes). The fact that it turns off immediately when you hit the starter shows the switch is being held open by the oil pressure. If it was flickering/lagging when you hit the button, THEN you'd be suspicious of low oil pressure (or the exhaust hitting the outside of the switch).
If it had low oil pressure, your cams would already be toast. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
Posted: 16:35 - 08 Jun 2018 Post subject: |
I'm not familiar with the engine but if you are determined to measure the oil pressure you 'may' find that there is a test port somewhere on the block. Look for a plug and slacken it. If there is oil on the thread it's 'feeling' oil pressure. If water/coolant comes out then its 'not the plug you are looking for'.
You might be able to determine what side is oil and what side is coolant by looking at parts diagrams.
Or buy a Haynes Book of Omissions for the beast.
If you are determined of course.
As Stinkers says, if low oil pressure then the damage is probably done by now. 😔
https://www.kawasakioriginalparts.com/road-bikes.html ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
B5234FT |
Posted: 10:35 - 11 Jun 2018 Post subject: |
stinkwheel wrote: | I'd suggest you probably don't need to. Those trochoidal pumps generally either work or they don't.
etc....
It works, however the light flickers at very low RPM on very hot idle, suggesting that perhaps the oil pressure is low. (it's not on continuously, or I'd suspect switch or wiring).
Do you happen to know what pressure the switch closes at?
MCN wrote: | I'm not familiar with the engine but if you are determined to measure the oil pressure you 'may' find that there is a test port somewhere on the block. Look for a plug and slacken it. If there is oil on the thread it's 'feeling' oil pressure. If water/coolant comes out then its 'not the plug you are looking for'.
https://www.kawasakioriginalparts.com/road-bikes.html |
As I said in the OP, I know where the test port is, which I found from the Haynes manual, I've just no idea what the correct adaptor is to test is as unlike car engines, it's not just a tapped thread into an old gallery.
Cheers |
MCN |
MCN Super Spammer
WD Forte |
WD Forte World Chat Champion
MCN |
MCN Super Spammer
B5234FT |
Posted: 10:30 - 12 Jun 2018 Post subject: |
As I said in the OP, I've found and removed the test plug and it looks like nothing I've seen before. It's not like a plug, it's like a long banjo bolt and the thread is nothing like 27TPI, more like 18. It's a pretty perfect match for metric 1.5mm, but the diameter doesn't match.
I cant drill and tap, as the thread isnt in the casing wall, its away inside.
I assume that there is a specific adaptor which replaces this bolt and provides an external oil port.
Many switches close at anything down to 3psi (vauxhall) 8psi is common enough on VAG stuff. That's why I asked if anyone KNEW, as 8-10psi at hot idle is survivable, 3 is not.
So, does anyone KNOW the answer, specifically for the GPZ? Because I can not-read-the-OP and guess the answer myself.
Thanks |
B5234FT |
WmY |
WmY Renault 5 Driver
The last post was made 5 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
