Revs go high in neutral
Plus Life EV
PostPosted: 18:03 - 09 Jun 2018    Post subject: Revs go high in neutral Reply with quote
hey everyone
Im still learning so forgive my ignorance!
basically after a short ride, when I put the bike (er6n 2012) into neutral the revs started climbing high, 4-5k before i switched the engine off.
I turned it back on and the revs went down to normal (1k ish). When I blipped the throttle it shot up to 3k and began climbing again and would not go down.
When i switched the engine on and went into first straight away it was fine, until I put it into neutral and it flew up again, without blipping the throttle.
The throttle isn't stuck or anything, its smooth and open/shuts ok. And I dont think the idle speed needs adjusting because at first it stayed at normal range. I don't know.
Any advice would be appreciated. I'd like to attempt the fix myself, but if its too serious itll just have to get to a shop.
cheers
Plus Life EV
PostPosted: 18:16 - 09 Jun 2018    Post subject: Reply with quote
Nevermind I solved it, the throttle closing bit (no idea what its called) wasn't closing by about 2mm. bit of lubricant and I should be ok. Looks a bit corroded from the winter, didnt think to ac-50 up there tbh.
NJD
PostPosted: 21:50 - 09 Jun 2018    Post subject: Reply with quote
You'll want to be sure rather than hope; sit on the bike with the engine running, in neutral, and turn the bars from full lock to full lock to ensure the cable isn't snagged (revs rise then you've got a routing problem).
Photo of the rusted area? If you can't be sure when the throttle cable was last lubricated and it looks funky then its probably time to get the manual out and see if its something you can do.
johnsmith222
PostPosted: 12:32 - 11 Jun 2018    Post subject: Reply with quote
I would use this as an excuse to start from the throttle tube down to the throttle body to clean everything up, lubricate cables etc. Also check for air leaks.
Might also be worthwhile to balance the throttle bodies with a morgan carbtune while you're there.
The last post was made 5 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 17 - Page Size: 41.5 Kb
