Vacuum test
chaza
PostPosted: 11:26 - 17 Jun 2018    Post subject: Vacuum test Reply with quote
Hi guys,
I have an ajs dd125e8, I've just done a vacuum test, the reading is fluctuatino around 10hg, does this sound ok to you.
One side tappets are very slightly noisier than the other, but she runs fine. I have noticed she back fires a little when I am changing down, should I be concerned about anything.
Thanks it's appreciated
Chaza
Teflon-Mike
tl;dr
PostPosted: 16:12 - 17 Jun 2018    Post subject: Reply with quote
AJS DD125.. benly twin derivative engine, single carb.
What vacuum test have you done?
Usual place a vacuum gauge might be found on a motorbike is to measure manifold vacuum when balancing multiple carbs your bike shouldn't have, AFAIK.
What are you trying to do?
chaza
PostPosted: 17:01 - 17 Jun 2018    Post subject: Reply with quote
I'm not trying to do anything in particular, I was checking the vacuum routinely, I wasn't sure if the 10hg was correct, it does have two carbs.
Because of the backfire I was unsure if they are set up ok
Thanks
Evil Hans
PostPosted: 19:06 - 17 Jun 2018    Post subject: Reply with quote
10 what Hg? mm, inches?
It's pretty meaninglessness anyway, as Tef says you'd only usually use it to compare relative values.
PostPosted: 19:43 - 17 Jun 2018    Post subject: Reply with quote
it do got a twin carb
https://www.ajs-shop.co.uk/acatalog/DD150E-4-0109100-E8.JPG
Some fluctuation is normal because of the valves opening and shutting so you wont get a steady reading.
Many gauge lines have wee screw valves before the gauge you trim to minimise this.
PostPosted: 19:58 - 17 Jun 2018    Post subject: Reply with quote
Agreed.
Also, what revs are you using? More revs means more vacuum.
chaza
PostPosted: 08:24 - 18 Jun 2018    Post subject: Reply with quote
Thanks guys, I was doing the test on idle, as I increase the vacuum responds as I would expect.
Anyway, I'll be doing a good road test soon, so I'll see.
As I said earlier it does backfire very slightly when I come down from 3 to 2, but overall she runs ok, my main concern was the carb setup, it's got two that is what led me to check the vacuum.
Cheers men
Evil Hans
PostPosted: 10:42 - 18 Jun 2018    Post subject: Reply with quote
So which was it? If it's mm you probably have a leak somewhere, but I'm assuming it's inches.
chaza
PostPosted: 10:57 - 18 Jun 2018    Post subject: Reply with quote
Sorry,
Yes it's inches he
The last post was made 5 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 17 - Page Size: 63.47 Kb
