Socket for an Octogan shape (8 point) 32 nut?!
cb1rocket
PostPosted: 19:22 - 18 Jun 2018    Post subject: Socket for an Octogan shape (8 point) 32 nut?! Reply with quote
Hello
Doing headstock bearings for mate's scooter. Sorted it in the end with a 32mm spanner but life could of been so much easier if I had a socket that fitted deep enough! Are these an oddball nut or can I get a socket that fits? The ones I found are too shallow.
https://cdn.bcf.44bytes.net/files/img_4349.jpg
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
WmY
PostPosted: 21:49 - 18 Jun 2018    Post subject: Reply with quote
https://www.banggood.com/32MM-45MM-Motorcycle-Odds-Sleeve-Front-Fork-Bearing-Octagonal-Nut-Tool-Repair-Tools-p-1081034.html?gmcCountry=GB¤cy=GBP&createTmp=1&utm_source=googleshopping&utm_medium=cpc_elc&utm_content=zouzou&utm_campaign=pla-gb-a-m-pc-0531&stayold=1&ID=510657&cur_warehouse=CN
"No. 4" perhaps?
barrkel
PostPosted: 22:42 - 18 Jun 2018    Post subject: Reply with quote
Honda sell one (part number for my SH300 is in the workshop manual). I just use a big spanner, like you. Has the significant advantage that you can loosen / adjust / tighten without needing to take the handlebars off, and steering head bearings often need a bit of tightening after they've bedded in.
07916KM10000 is the part number, described as headset locknut wrench. Quite expensive, spanner was much cheaper.
cb1rocket
PostPosted: 08:53 - 19 Jun 2018    Post subject: Reply with quote
Cheers Barkell, I asked since it would of avoided the need to take off so many plastics. I had to take the front inner panel off just so there was enough clearance for the spanner haha. That was another 2 hours unnecessary work...sigh.
The last post was made 5 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 17 - Page Size: 41.5 Kb
