Bike wont turn off by key.
R1stu
Shrek!
PostPosted: 19:28 - 19 Jun 2018    Post subject: Bike wont turn off by key. Reply with quote
The other half has an HN125-8 and it works all good and nice, apart from when you turn the ignition off, the bike still runs.
So to turn the bike off, you need to use the kill switch. I am not sure if its the wiring as its been cut and pasted, or if its the ignition itself.
Anyone got any ideas on where to start?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 19:58 - 19 Jun 2018    Post subject: Reply with quote
Wild guess, it's an AC CDI type bike where the ignition and/or kill switches ground the source coil output to ground to stop the motor.
If it is, then it may be poor connections or 'owner improvements'
to the wiring.
Or. fitting an ignition switch from another/similar bike
that doesn't have the same electrical functions.
Maybe it's a bad switch
Maybe I got it all wrong and talking bollox
huoniao's?
geddit ?
eh ?
oh please yerself
R1stu
Shrek!
PostPosted: 20:12 - 19 Jun 2018    Post subject: Reply with quote
How would I know if its an AC ignition system? It is the Huiaon 125
PostPosted: 20:50 - 19 Jun 2018    Post subject: Reply with quote
Damned if I can find a wiring diagram now, but I think that's right, and the cut off switch essentially does the same thing.
Aside, the engine will run just fine with the main fuse blown, so that supports the idea that the ignition circuit is always live unless something actively stops it from being so.
Sight unseen I'd guess just a bad soldering job on the ignition barrel, or a corroded wire, but you'll need to go in with a multimeter to find out.
R1stu
Shrek!
PostPosted: 21:46 - 19 Jun 2018    Post subject: Reply with quote
I was trying that last night. But unable to find one single wiring diagram that matched completely. Even the lexmoto vixen, which this rips off seems to have differences in colours.
jaffa90
PostPosted: 00:35 - 20 Jun 2018    Post subject: Reply with quote
Ignition switch useless.
Teflon-Mike
tl;dr
PostPosted: 04:36 - 20 Jun 2018    Post subject: Reply with quote
Generic Small Honda ignition, the CDi unit has a wire to 'make' a circuit to earth to kill sparks, rather than switches to 'make' circuit to feed coil and make them.
Handlebar kill switch makes circuit; ignition barel 'off' makes circuit. Side-Stand inhibitor makes a circuit.
I would start looking though in the headlamp. Early genuine Honda ignition barels had a wire from the CDi, black and white OTMH, in the multi-way connector in the headlamp. Later, and most Chinky derviavtives had a seperate wire from the key barel, with a bullet on the end, to a seperate connector, to make it easier to dog in the 'kill' feeds from the side-stand or clutch or kill switch.
If OE switches replaced, you could have a genuine Honda switch, wich isn't connected to external kill wire; or you could have generic chinky barel with external kill wire not connected to the honda multi-way.... OR you could just have the kill wires from the barel and loom hanging loose where some-one has pushed in the lens after messing with the headlamp bulb!
WHICH, as handlebar kill you say still works, is probably the most likely.
PostPosted: 09:21 - 20 Jun 2018    Post subject: Reply with quote
T'other way around. Huoniao and Haotian were prior in-house brands of Jiangmen Dihao. The Lexmoto rebadgings came later.
R1stu
Shrek!
PostPosted: 12:24 - 20 Jun 2018    Post subject: Reply with quote
There is a lot of bodging inside. the prev owner has bypasssed the side stand cutoff. and there is a green and black/white wire cut and not doing anything in the multi connector from ignition.
PostPosted: 13:04 - 20 Jun 2018    Post subject: Reply with quote
Probably as well, there is (or was) a connector block for it placed right underneath the engine in a prime location to corrode.
PostPosted: 15:05 - 20 Jun 2018    Post subject: Reply with quote
The ignition switch should have a 6 way connector.
The green and black/white wires are the ones that get shorted to stop the sparks/motor
From what I see they use Honda colour conventions ( mostly)
and it is yer typical AC CDI setup
BTW
No I aint psychic, I just looked here and inferred it from images
single cylinder, 125, OHV, carbed, AC CDI, Honda colours etc
https://china-parts.co.uk/acatalog/copy_of_Lexmoto_Vixen.html
The last post was made 5 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.36 Sec - Server Load: 0.46 - MySQL Queries: 17 - Page Size: 76.84 Kb
