Injector Cleaning.... Voltage?
jpno5
PostPosted: 14:04 - 21 Jun 2018    Post subject: Injector Cleaning.... Voltage? Reply with quote
Last time my injector needed cleaning i just replaced it with a second hand one from my old bike.
A year later the replacement needs cleaned. Rather than buy another i thought i'd have a bash at cleaning the old one...
I fired a 9v battery onto it and tried to force some injector cleaner through from a can as seen on some youtube vids. I couldn't get it to spray at all, i hear the clicking on the injector when i apply power.
Should i be giving it more voltage? or is there something i'm missing when doing this?
Bike is a suzuki gz125.
jpno5
PostPosted: 15:19 - 21 Jun 2018    Post subject: Reply with quote
also i have 2 hoses going to mine, whats that all about? in the youtube vids i only see one. Fuel filter built in maybe ? https://www.ebay.co.uk/itm/SUZUKI-Genuine-New-Motorcycle-Parts-Address-V125-Fuel-Injector-15710-33G01/302778657074?hash=item467f03a932:g:wm4AAOSw~3pafxok
PostPosted: 20:30 - 21 Jun 2018    Post subject: Reply with quote
GZ125 or Address125?
make yer mind up
Anyway 2 port probably means your 'injector' is a discharge pump and the second port a return
jpno5
PostPosted: 01:20 - 22 Jun 2018    Post subject: Reply with quote
suzuki marauder gz 125 2011, that is the injector for it that i posted although it says for different model.
as you might have guessed i know shit about bikes! that link i posted is the item in question, confirmed with part numbers.
Whats the difference . injector . / discharge pump? the system behind it...
How does the pump work? And can it be cleaned?
PostPosted: 19:12 - 22 Jun 2018    Post subject: Reply with quote
Conventional injectors use a pressurised supply from a pump often in or near the tank and the injectors hold back this pressure until triggered by the controller when they open briefly to allow a bit of fuel into the inlet manifold.
DCPs are gravity/low pressure fed and when triggered, actually pump
the fuel in the manifold themselves so they're actually a pump and injector in one.
https://en.haojue.com/public/showInfo_103_433_436_i102.htm
jpno5
PostPosted: 21:44 - 22 Jun 2018    Post subject: Reply with quote
Thanks for the explanation, any idea how it can be cleaned, or am i best just trying one of the fuel additive things and try that?
The last post was made 5 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.3 - MySQL Queries: 17 - Page Size: 48.72 Kb
