Aprilia RS 125 - decatting and exhaust appendix
DEADmetal
PostPosted: 14:25 - 08 Jul 2018    Post subject: Aprilia RS 125 - decatting and exhaust appendix Reply with quote
This exhaust is taken from a stock factory FP 2006 RS 125 new shape. I'll be cutting out the cat and recirculation pipe, so i need to know what's this appendix for. If it's a restrictor, i'll cut it out as well.
https://i.imgur.com/vSCzTO3.jpg
stevo as b4
PostPosted: 14:54 - 08 Jul 2018    Post subject: Reply with quote
It's a resonator tube like those fitted to scooter exhausts. It needs to be removed and plated over. As it is, it's adding volume to the exhaust and changing the resonant frequency of the pressure waves. It can make the pipe work better at much lower Revs, but it won't make any power where the engine is designed to work properly.
Will be interesting if you dyno this bike once you've removed all the restrictions and jetted it correctly, just to see if you can get closer to early RS125 extrema bhp figures, or if there's other changes made to the exhaust, engine, carb or ignition to de-tune these later bikes and improve their emissions.
Daft idea it was trying to build a clean running two stroke. It goes against every working principal of them, and they are supposed to pollute the planet like a mother fucker.
DEADmetal
PostPosted: 16:40 - 08 Jul 2018    Post subject: Reply with quote
stevo as b4 wrote:
Thanks for the clarification. I was actually surprised by low RPM performance of this bike but it performs very well, for what it is (stock), on high RPM as well. It reached 100 mph with this stock exhaust. It would have accelerated a few more mph but it's limited to 100 mph by gearing - at 11k RPM.
The exhaust is done. I'll hopefully solve my PV problem and see how it rides.
It would indeed be interesting to test it on the dyno - i'll look into doing so. As for jetting, it's hard to find someone who could do it properly for me. Here in Lithuania, mechanics see no profit in working on two strokes as the only ones who are on the road are 50 cc - and mostly scooters, and very rarely, bad condition 125 cc bikes ridden by kids who don't care and / or have no money for maintenance.
I don't know how to set the jetting myself. Perhaps you could direct me to some proper tutorials?
DEADmetal
PostPosted: 15:54 - 14 Jul 2018    Post subject: Reply with quote
By the way, do I need to rejet it after decatting it (emptied the expansion chamber completely)? The bike is otherwise stock (and fullpower), with stock jetting.
I wasn't actually worried about it, because i've heard that the stock jetting is rich and besides my exhaust can tip was getting oiled up a bit. However, it's better to be sure than sorry.
Riejufixing
PostPosted: 23:01 - 14 Jul 2018    Post subject: Reply with quote
If you've done that, I should think it quite likely that changes will be needed. Suck it and see.
The last post was made 5 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 17 - Page Size: 46.43 Kb
