Honda Cub C70 Will not start
dj_wazz
PostPosted: 16:01 - 18 Jul 2018    Post subject: Honda Cub C70 Will not start Reply with quote
Hi,
I'm looking for advice, I've got Honda Cub C70 1986, The bike will not start and hasn't started for many years now but this spring I've cleaned out the fuel line plus put inline filter on, fresh fuel, cleaned out the carb, new air filter, new spark plug and new battery and also I cleaned up the magneto fly wheel.
even after all that work it still won't start, little to no compression on kick starter without the choke being fully open.
the fuel is getting to spark plug I can smell it on the plug.
spark plug sparks outside the chassis when tested.
thats about it just cant get it to come back to life.
Honda Cub Problems
UnknownStuntm...
PostPosted: 16:54 - 18 Jul 2018    Post subject: Reply with quote
Has that one got points? If so, they're notoriously difficult to set exactly right. Most likely the timing will be out a teeny bit. When I had one I got a timing light and had the process down to an art. But even doing up the screw put it out slightly so you have to compensate for this while you're setting it.
dj_wazz
PostPosted: 19:09 - 18 Jul 2018    Post subject: Reply with quote
I had a look for the points I cant see them on the magneto am i right in thinking they would be behind the flywheel?
Honda Cub Problems
Pete.
PostPosted: 19:28 - 18 Jul 2018    Post subject: Reply with quote
Yes the points are 'inside' the flywheel. Look through the slot in the front as you turn the flywheel and you'll see a small screw with a plate behind it which has a slot in the edge. That slot is for adjusting the gap with a screwdriver.
Can't remember if you can get on the C70 points with a (brass) feeler gauge to set the gap, I always do it by eye and set the timing with a small bulb.
a.k.a 'Geri'
PostPosted: 10:26 - 19 Jul 2018    Post subject: Reply with quote
Brass feeler gauges eh? Didn't know they existed, now that would have saved a lot of frustration back in the day..
The last post was made 5 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 17 - Page Size: 44.41 Kb
