USD forks stanchions threaded into the lower legs, sealing.
Riejufixing
PostPosted: 23:48 - 26 Jul 2018    Post subject: USD forks stanchions threaded into the lower legs, sealing. Reply with quote
The Rieju RS3 125cc fork stanchions are threaded into alloy legs (see: https://www.bikechatforums.com/viewtopic.php?t=324969 ).
The threads need to be sealed I assume, to stop fork oil from passing the threads.
If that's true, what to seal them with? Ordinary thread seal e.g. Loctite 565? PTFE tape? Something else?
almostthere
PostPosted: 16:20 - 27 Jul 2018    Post subject: Reply with quote
Confused wut?
Beer, It's the reason I get up every afternoon
www.mfairco.uk
Riejufixing
PostPosted: 16:27 - 27 Jul 2018    Post subject: Reply with quote
It's OK, it seems I'm doing something that is rarely done. Looking at the picture, number 15 screws into number 14. Number 15 itself is full of oil, and the threads on the number 14 end of number 15 (I have now skilfully edited the picture) need to be sealed, else oil will creep through between the screwed-in number 15 and the number 14, which is undesirable.
PostPosted: 17:49 - 27 Jul 2018    Post subject: Reply with quote
Again, the answer will probably be, "look at the old one, what did they do there?".
Check for an o-ring or fibre washer in the bottom of the end casting that's not shown on the parts diagram. Have a close look at the thread. Might it be a taper?
In any case, I can't think of any way in which it would be wrong to use PTFE tape on those threads.
PostPosted: 17:59 - 27 Jul 2018    Post subject: Reply with quote
That's also the answer to many other questions the OP has. Mr. Green
Riejufixing
PostPosted: 18:54 - 27 Jul 2018    Post subject: Reply with quote
OK I'll see what comes out. Um. The thread's straight ISO metric fine 40mm x 1.5.
Riejufixing
PostPosted: 18:59 - 27 Jul 2018    Post subject: Reply with quote
Why me Exclamation Why, oh why, why?? Yes, I know, I bought a crashed thing that also needs maintenance and these days outside the dealer there's not a lot going on (except in this forum and similar). I will bore the tits off anyone who cares to read by reporting back...
Pete.
PostPosted: 20:03 - 27 Jul 2018    Post subject: Reply with quote
I would clean it up with brake cleaner and assemble using loctite 243.
a.k.a 'Geri'
temeluchus
PostPosted: 20:22 - 27 Jul 2018    Post subject: Reply with quote
This.
Riejufixing
PostPosted: 16:42 - 31 Jul 2018    Post subject: Reply with quote
No sealant seems to be in use. There was a light-alloy component pushed into the bottom of the fork stanchion (easy sliding fit) holding two "O" rings sealing to the insides of the stanchion. This component also held another O ring sealing to the machined flat inner bottom face of the lower leg.
See "Removing stanchions from USD fork alloy lower legs." write-up:
https://www.bikechatforums.com/viewtopic.php?t=325193
The pictures attached showthe component with O rings, and the stanchion threads filled with corrosion from the inside of the lower leg from when it was withdrawn.
The last post was made 8 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 65.57 Kb
