jtheobald |
jtheobald L Plate Warrior
Posted: 12:17 - 08 Aug 2018 Post subject: YZFR125 - stuck Pinton Pin |
Hi,
Son's bike seized as ran out of oil . Piston disintegrated. Removed cylinder etc and piston, but the pin is stuck. I understand best way to remove is to heat the conrod - my question is will this destroy the conrod and it will need to be replaced before fitting a new piston?
All advice must appreciated |
Riejufixing |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 13:50 - 08 Aug 2018 Post subject: |
Is thegudgeon pin stuck in the little end or in the piston ?
Have the gudgeon pin circlips been removed?
If genuinely siezed... what else has been damaged through oil starvation?
If conrod stuck on gudgeon to piston, is the conrid a split plain shell bearing at the bottom?
Does crank need regrind or rebuild, and new bearings, big ends and mains?
What state the bore? Piston? Piston Rings?
What about the two camshafts running in the head, usually first things to suffer when enginev starved of oil?
getting piston off conrod could, in the grand sceme be rather irrelevent, if most of the rest of the engine needs replacing anyway...... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
jtheobald |
MarJay |
MarJay But it's British!
jtheobald |
jtheobald |
P. |
P. Red Rocket
Riejufixing |
MCN |
MCN Super Spammer
Posted: 17:25 - 08 Aug 2018 Post subject: |
It'll be easier removed on the bench. Then you can just rest the side of the piston against a suitable tube and drift the pin out into it.
If it's seized in the small end, you're probably looking at a crank replacement/rebuild anyway because as far as I can see, it's a plain small end. Although the big-end is a roller bearing which will be more tolerant of oil starvation than a floating bush.
Any vertical play on the conrod? If there is, you're looking at a minimum of a crank rebuild and the viability of the motor is highly questionable because if those bearings have gone, what else has? There are more crashed R 1/8ths out there than there are blown up ones, this generates a surplus of engines.
bits of piston in every part of the motor.
EDIT: If I read one of your above posts correctly and it's ripped the gudgeon pin out of the bottom of the piston, I'd be amazed if it hasn't also bent the conrod. The pin probably wont move because it's bent too. The forces involved with this type of failure happening are astonishing and the metal becomes pretty plastic. Your episton went from moving at an appreciable fraction of the speed of sound to a full stop in a couple of mm. That's a lot of energy to dissipate as (mostly) heat. I've seen a conrod bent a full 360 degrees. It may even have bent the crankpin.
There will certainly be assorted alloy and hardened steel fragments strewn about in the crankcase, if the piston's been ripped in half, it's a deffo full strip. I've rebuilt enough engines after that to know the bits get literally everywhere. In the three or four revolutions the motor manages to do post self-destruct, it will have picked up alloy fragments and tried to pump them round the oilways and valvegear too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
P. |
P. Red Rocket
Riejufixing |
P. |
P. Red Rocket
jtheobald |
Posted: 12:14 - 12 Aug 2018 Post subject: |
Fair enough.
It's easy to change the engine number though. You just get a letter from a garage on headed paper stating the registration and frame number and confirming it now has engine number XXX fitted then send it off with the completed logbook. Doesn't even cost anything. I did one earlier this year.
A receipt for the replacement engine with the number on will also suffice instead of a letter.
In terms of the mileage, the only time you'd be risking problems is if you SELL it with an incorrect/misrepresented mileage. That said, the mileage goes with the chassis, not the engine. If you fitted a brand new engine, you couldn't set it to zero so your mileage will still be be correct. My current bike is on its 4th speedo. When you look at the MOT history, the recorded mileage fluctuates up and down wildly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
jtheobald |
ThatDippyTwat |
jtheobald |
The last post was made 5 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
