DrSnoosnoo |
DrSnoosnoo World Chat Champion
el_oso |
el_oso World Chat Champion
Posted: 09:05 - 16 Aug 2018 Post subject: |
bin the bt-023
Ideally you want to gradually stop the slippage. You almost always don't want to snap the throttle shut as the sudden grip could stand the bike up violently enough to highside and flip you off.
When I'm in this situation I tend to hold the throttle constant, and slowly back off if needed. The rear comes back under control and that ends the drama. ____________________ Duke 390
Car: Jeep Wrangler 4.0L |
wr6133 |
wr6133 World Chat Champion
Ste |
Ste Not Work Safe
Posted: 09:39 - 16 Aug 2018 Post subject: |
I'm impressed that you haven't used the usual excuse of diesel when being slightly cack handed with the throttle. |
DrSnoosnoo |
Posted: 09:55 - 16 Aug 2018 Post subject: |
I read that the BT023 won't last too long anyway so I'll change them later - I may even get Avons!!
@Ste - It was wet ...
I only ever had the ZZR6 step out on me once, and I described how it happened on here and people told me diesel was the likely reason for that one. I had a light front a hundred metres before an overtake and the back wheel slipped then.
I always thought to just hold a constant throttle when slipping and think I did it but in reality it happens so quick it's not always easy to think about actions before enacting them.
I imagine that if you give more throttle you'll spin up more, sliding more?
The throttle on this 1100 is much more sensitive than my 600, perhaps because I never adjusted the throttle cables, so the 11 doesn't need too much input at the grip to give some beans.
____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
G |
G The Voice of Reason
natefz6 |
natefz6 Brolly Dolly
trevor saxe-coburg-gotha |
Polarbear |
Polarbear Super Spammer
Posted: 12:50 - 16 Aug 2018 Post subject: |
As said, the worst thing is to snap the throttle shut. If Rossi can drift his race bike I'm sure you can do the same on a big bad ZZR1100.
From what I remember the back tyre on the ZZR11 is quite skinny compared to todays big bikes set up. Not sure if that would make a difference or not.
Anyway, I fitted Avon Storms to my gen 1 busa and they lasted well and I never had a problem with grip. I'm sure they would be fine on the ZZR. ____________________ Triumph Trophy Launch Edition |
DrSnoosnoo |
MCN |
MCN Super Spammer
Posted: 15:29 - 16 Aug 2018 Post subject: |
A High-Side is when the rear tyre looses grip, suspension relaxes, the tyre slips side ways, when it finds grip, the torque compresses the rear suspension again.
If you are giving it the beans at the same time (which probably caused the slip) then the final part of the high-side is the sudden rebound of an over compressed rear and that bucks you off like in your first rodeo.
I wouldn't give it any more juice if I felt the slip. (That caused it.)
There has to be a lot of skill and experience to recover the bike then.
Backing off a bit will only help. Rolling off the throttle.
But banging it shut will cause another sort of issue.
The real thing to remember is that there are very few roundabouts on race tracks and private roads.
You are on a public road that the public have free access to.
That is stuff you can hit.
And the PoPo will defo give you a tug if they see you careening around a roundabout. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
DrSnoosnoo |
Posted: 16:11 - 16 Aug 2018 Post subject: |
MCN wrote: | The real thing to remember is that there are very few roundabouts on race tracks and private roads.
And the PoPo will defo give you a tug if they see you careening around a roundabout. |
I don't want to give the appearance I was being a knobber ... I'm commuting, not MotoGPing ____________________ I'm Sam; Northern, Ginger, Lover
G |
Confusion |
Confusion Scooby Slapper
MCN |
MCN Super Spammer
chickenstrip |
chickenstrip Super Spammer
Posted: 19:05 - 16 Aug 2018 Post subject: |
I found BT023s didn't inspire much confidence in the dry, never mind the wet, so another vote for binning them. Lots of much better tyres out there nowadays, and it is the one thing to make riding enjoyable - having confidence in good tyres. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
natefz6 |
talkToTheHat |
talkToTheHat World Chat Champion
G |
MCN |
MCN Super Spammer
Posted: 16:29 - 19 Aug 2018 Post subject: |
Rotation my Donkey.
Look at the video 0:24 seconds.
The rider only leaves the saddle after the suspension reaches full extension again.
It is designed to maintain tyre contact with the road surface over a relatively smooth surface. The bumps it normally encounters on a track are small. (Different design and settings for road racing etc.)
The intended design is not to absorb the massive forces such as those of a slip and grip in a high speed cornering manoeuvre.
The suspension probable seldom bottoms out in normal cornering.
Only the front will work as hard as that.
The suspension only does what it is designed to do and maintain the bike at its ride height.
It doesn't have anything to do with the rebound dampening. If it was dampened so much it would be too slow for the normal bumps.
It gets overloaded in a high side.
Someone did the maths on the forces (moments) for us. Thanks.. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Kawasaki Jimbo |
talkToTheHat |
MCN |
MCN Super Spammer
Islander |
Islander World Chat Champion
The last post was made 5 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
