Sooty Plugs
delwil123
PostPosted: 15:14 - 19 May 2020    Post subject: Sooty Plugs Reply with quote
Hi,sure this must have been discussed before but can anyone guide me through the procedure to fix sooty black plugs. I recently fitted 2 new coils and 4 spark plugs and the bike was starting and running great. However on my second run of about 10 miles or so it kept stalling on tic over and just not going as it should. I removed the plugs and they are black sooty. Any advise appreciated. Its a 1979 GS 550
Del
mickyboy1
yen_powell
PostPosted: 15:49 - 19 May 2020    Post subject: Reply with quote
Is the choke sticking on?
XT1200Z and a DR350 in bits
stevo123
PostPosted: 20:55 - 19 May 2020    Post subject: Reply with quote
As above, also check plug number is correct. A colder plug will not help.
jaffa90
PostPosted: 00:01 - 20 May 2020    Post subject: Reply with quote
Have you got cracking blue sparks?
What happens if you leave the fuel tap in PRIme position?
Have you a mouse nest in the air box or a dead one in the exhaust?
delwil123
PostPosted: 08:21 - 20 May 2020    Post subject: Reply with quote
Choke is fine and works as should.
I put in Iridium plugs some time ago as that helped with starting, but whatever plugs used they all go sooty dry black.
Have put the air screws at 2 turns out so will see if that has made a difference.
Thinking of buying a carb sync kit do you think that may help.
Fuel tap in any position works fine.
mickyboy1
The last post was made 6 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.45 - MySQL Queries: 14 - Page Size: 42.41 Kb
