| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 12:45 - 14 Sep 2004 Post subject: [HELP!] Electrical issues |
The ZZR died on the way back from Wales on Sunday. Engine would spin on the starter, but she wasn't even trying to catch, everything else seemed fine (lights, console etc) so I put it down to a dodgy connector.
Called the AA, got the bike home and into the garage and then just plugged the optimate in and left it. I have a fairly heavy chest infection at the moment, so been feeling too ropy to really get down and strip everything before now.
Went into the garage earlier, unplugged the optimate and turned the engine over on a whim. Off she goes on the first push of the starter.
Basically, does anyone have any recommendations as to good places to start the hunt for an intermittent electrical like this on a ZZR? I'm something of an electrical newbie, last time I had anything to do with the wiring on a bike I fried my GPz, so approaching this with alot of caution  ____________________ I'm immortal. Well, so far. |
| Demonic69 |
 Demonic69 The Pink Rhino
| dibbster |
 dibbster Nearly there...
 Posted: 13:21 - 14 Sep 2004 Post subject: |
How old is the battery? and the bike?
I woul agree with Demonic that the rectifier unit would be a good place to start grab a copy of the wiring diagram and it should be easy to test whether or not it is functioning. ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
| Tarmacsurfer |
| Big Pete |
 Big Pete Spanner Monkey
 Posted: 14:04 - 14 Sep 2004 Post subject: |
if the engine spins over fine then theres no problem with the battery, its going to be in the ignition circuitry. Likely places are -
sidestand cut out corroded
kill switch shorting to earth
broken /corroded power feed to ignitor unit
internal contact problem at the main igntion switch ( but less likely as other stuff works)
corrosion/arcing damage in the fuse box
Fuse failing due to vibration - this ones a real bastard because the element cracks through and you cant see it, but it is an unreliable contact, particularily under load.
last but not least do you have an alarm with ignition cutout? if so check all the connections into the main Kwak loom, if there are the blue plastic connectors, remove them and do the job properly because they are the work of the devil
good luck mate, intermittent electrical faults can be a pain to find.  ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
| Tarmacsurfer |
 Posted: 14:20 - 14 Sep 2004 Post subject: |
Just replaced the main ignition switch, the day before the barbeque in fact
Side stand cut out is long gone, but I'll check the bypass.
Kill switch shorting, possible. The switch gear on these is prone to wearing, start buttons particularly.
Fuse box may well be worth checking, they've not been touched in a while. Given the problem seems to occur once the bikes warm then it's a possible.
Meh. I hate intermittents. Broke is fixable, but tracing something like this is a nightmare  ____________________ I'm immortal. Well, so far. |
The last post was made 21 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
