Vibration
PostPosted: 17:20 - 27 Aug 2018    Post subject: Vibration Reply with quote
https://www.youtube.com/watch?v=IKwWu2w1gGk
BanditsHigh
Worse than a woman
PostPosted: 19:32 - 28 Aug 2018    Post subject: Reply with quote
Interesting Thumbs Up
Hong Kong Phooey
PostPosted: 22:59 - 28 Aug 2018    Post subject: Reply with quote
Naw man, you just use the same nuts and bolts that the Junker vibration test machine is made of.
Dave....
PostPosted: 23:43 - 28 Aug 2018    Post subject: Reply with quote
Bet they cost a few quid though.
Honda Africa Twin
rpsmith79
PostPosted: 07:25 - 29 Aug 2018    Post subject: Reply with quote
Yep, i have used them before, and they are great, but expensive
They also make a right mess of the mating face you are bolting too (as you can see at the end of the video), so don't use on anything painted or chrome plated etc, as it will chew it up
PostPosted: 17:52 - 29 Aug 2018    Post subject: Reply with quote
Exactly.
This is where the great mysteries of engineering come into it.
There is an engineered solution for every problem.
It's when problems are 'solved' by folk who are not engineers we see problems.
The most common failure in bolting stuff is whether to use lubricant of not.
A lubricant massively increases a fastener's clamping force. Things can be crushed by the extra force exerted even thought the 'correct' torque for the bolt dimension is used.
It is actually Rocket Science.
RhynoCZ
PostPosted: 18:39 - 29 Aug 2018    Post subject: Reply with quote
This +1Nm
For most of the things you work with (motorcycles/cars) the manufacturers give you the dry torque values. If you lubricated your bolts, the torque wrench, although set correctly, will allow way more torque before it clicks or the head of the bolt just snaps off before that.
The most common issue is wheel bolts and nuts on cars. Even profesional mechanics lubricate them and then even tighten them with their fancy air guns, which is wrong on its own (not the topic in question).
When you put way too much torque on your wheel bolts/nuts, the bolts/lugs do stretch and may even snap clean off when you brake, accelerate, turn or just go through a pothole. Not to mention the fun you'll have when you're going to need to change the wheel at the roadside.
The last post was made 5 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 55.37 Kb
