water pump Kawasaki gpz600
Busby
PostPosted: 10:19 - 04 Sep 2018    Post subject: water pump Kawasaki gpz600 Reply with quote
Hi, I'm changing the water pump on my 1987 Kawasaki gpz600. I see there is no gasket for this and it relies solely on the internal rubber seal, which I have a new replacement! Is it advisable to put some mastic between the 2 faces? If so what should I use? Regards Busby. Shocked
pompousporcup...
PostPosted: 12:23 - 04 Sep 2018    Post subject: Reply with quote
Similar in design the gpz900r variant, i rebuilt my pump and re-fitted it, just using some grease on the rubber seal to aid fitting/sliding the pump into the housing. A good seal, well fitted shouldn't leak.
The cog on the water pump needs to line up with its counterpart in the engine so make sure they do. If you can, leave the front face of the water pump off and spin the engine over to make sure the pump turns Thumbs Up
There is a gap of 1 year, 247 days between these two posts...
henrywilson This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 6 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 35.88 Kb
