ZXR 400 Starting problems
GeorgeBuck
PostPosted: 20:00 - 06 Sep 2018    Post subject: ZXR 400 Starting problems Reply with quote
Hi all I've recently bought a zxr400 with 4500 miles, I've ridden it for about a month until the cam shaft chain guide snapped on my while riding(I tried starting the bike with the start button but nothing, then push started it and run with an awful grinding noise). since then I've replaced the broken parts and what not, had the timing done correctly to my knowledge. During the process of repairing it I haven't been able to start the bike with the start switch, I can hear the engine turn over but it doesn't start. Even put my finger on the end of the spark plug (plugged into the ignition coil) and wasn't getting a shock when starting it. So with no idea what to do put it all back together and push started it like before and it ran like a dream but still doesnt start by the switch.
I thought it could be the cdi box, When repairing the bike the battery was dead and i recharged it and put a multi meter to it and it still reading 12v not too sure if it could still be the battery even if holding 12v.
Any idea on where to go from here would be greatly appreciated.
jakebrownbass
PostPosted: 20:13 - 06 Sep 2018    Post subject: Re: ZXR 400 Starting problems Reply with quote
New battery before anything else.
Hyosung GTR 125 ---> Suzuki GSXR 400R ---> Kawasaki 636 ---> Break ---> Kawasaki Versys 650
Fisty
PostPosted: 08:08 - 07 Sep 2018    Post subject: Reply with quote
Have you turned the fuel tap back on?
TL1000R | Hayabusa | ZXR400
Monkeywrenche...
PostPosted: 10:25 - 07 Sep 2018    Post subject: Re: ZXR 400 Starting problems Reply with quote
To Check for a spark rest the plug on the engine and look for a clean blue spark from the plug while cranking. After crankning the bike over are the plugs wet with fuel? you need to pull one staright out before it has a chance to evaporate. Report back which (if either) is missing and we can give more directed suggestions.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 2.09 Sec - Server Load: 4.25 - MySQL Queries: 16 - CDN Objects: 32 - Page Size: 42.58 Kb
