stevo as b4 |
Posted: 17:24 - 09 Sep 2018 Post subject: Uprate clutch or not? |
After having spent this afternoon carefully removing old gasket residue and sealant from my KMX 125's clutch cover I've prepped the cover for re-painting. Im changing the kick start oil seal and water pump seals as a matter of course too.
However without removing the engine, it's hard to get the clutch cover off without scratching the paint, so I don't really want to go back in here for a while.
The clutch was new 500miles ago and everything looks fine. But I don't know if I should be thinking of fitting an uprated clutch, heavy duty springs or a KMX 200 basket and plates set?
I'm slightly tuning the bike, it's going to be closer to 140cc and with a new pipe, bigger carb and programmable ignition. If it say ends up making 5-6bhp more and a bit more torque is it likely to need anything doing to handle it? My gut says the 125 std clutch should be fine, but I don't want to go back inside it again if possible.
I only took the cover off to change the power valve governor springs to one that operates at lower rpm for the full power bike, talk about a can of worms or should that be a can of paint? |
P. |
P. Red Rocket
chris-red |
Riejufixing |
stevo as b4 |
Posted: 22:24 - 09 Sep 2018 Post subject: |
I've actually got a set of +15% stronger EBC clutch springs I bought, but wasn't sure if it'd make the nice light clutch heavier, but I guess it won't, as the KMX 200 runs stiffer springs and an extra set of plates in a taller basket and they are fine.
Think I'll fit them anyway, and while I'm at it I can replace the gear change shaft oil seal, that has a slight weap. |
Shaft |
Shaft World Chat Champion
Posted: 23:09 - 09 Sep 2018 Post subject: |
Genuine (but lighthearted) question - are you ever going to stop cocking around with this thing and actually get it done?
Seems like you've been talking about it since I joined BCF, but 8 years later, there's not been so much as a single picture and you're no nearer to getting it finished.
Uprated clutch for an extra 5 bhp - SRSLY? ____________________ Things get better with age; I'm close to being magnificent........
stevo as b4 |
Shaft |
Posted: 23:11 - 10 Sep 2018 Post subject: |
I would throw the bike back together with whatever works, do your event and get it out of your system.
Both of them are financial cul-de-sacs, but the car is obviously what floats your boat (you don't waste many opportunities to give it a mention) so put everything into that and, maybe, come back to bikes at another point.
I don't know how old you are, but you've already decided hi-po super bikes aren't for you, so age won't be a barrier to getting back into 2 wheels later on. ____________________ Things get better with age; I'm close to being magnificent........
stevo as b4 |
Posted: 18:56 - 12 Sep 2018 Post subject: |
Everything I own is a financial cul-de-sac but I won't let it worry me and nor should you really. I'd class all my vehicles as toys as I drive company vehicles for work, and can get to 75% of the places I want to regularly go either by bus, train or cycle.
Its different and perhaps hard to comprehend to someone who's bikes have to be useful and earn their living or someone who doesn't drive etc.
I don't know what I've spent on my KMX this year? The cylinder conversion was £320, the Radiator was about the same, carb £140, exhaust £300, and then probably around £250 of bolts, fasteners, gaskets seals and small bits. I don't count it up, just when I've got spare money I'll buy things I need or think I need, and when I haven't I walk away from it and leave it for a couple of months or so.
I won't sell the car, as I'd want something else to fill it's place and whatever vehicle it was would never be sensible so what's the point?
Anyway I'll put my clutch back together at the weekend and today I picked up a gold MX pro chain for it, as seeing as I've got to split the chain to fit my new sprocket I thought I might as well replace it? |
The last post was made 5 years, 227 days ago. Instead of replying here, would creating a new thread be more useful? |
