quality4455 |
quality4455 L Plate Warrior
Jewlio Rides Again LLB |
Jewlio Rides Again LLB World Chat Champion
Posted: 21:44 - 12 Sep 2018 Post subject: |
Tried spraying easystart into the airbox? ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
quality4455 |
jaffa90 |
jaffa90 World Chat Champion
quality4455 |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 15:47 - 13 Sep 2018 Post subject: |
Isn't 2014 on the change-over between carb & EFi?
You say 'Fuel-Good'... do you mean that it's fresh fuel? Or a good brand? Or that the spark-plug smells of the stuff?
Is it getting to the cylinder? Is too much getting to the cylinder? Choke/Cold-Start circuit?
When you rebuilt, did you time the cam in correctly?
Did you set tappet adjustment right?
Did you use assembly lube?
I tend to use a lot of two-stroke oil on rebuilds on things like piston rings and the bore, as it burns off more easily when running, but is there on first fire when needed.....
Thicker oil, tends to foul the plug and make first fire rather short, if at all...
No oil, can leave compression low, esp if rings haven't been soaked, and leave new bits to cut themselves to bits on first fire.
BUT... right lines: Fuel, air, spark, compression.... should have all ingredients for life... so...... if it aint living... either one of them AINT present, or one of them aint present in the right amount, or at the right time..... and back to the head-scratching. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 5 years, 220 days ago. Instead of replying here, would creating a new thread be more useful? |
