400 Bandit 16 valve with shims at In and Ex
Paulcronje
PostPosted: 06:50 - 13 Sep 2018    Post subject: 400 Bandit 16 valve with shims at In and Ex Reply with quote
Hi there
I know 3 types of Bandit engines.
1) 400 16 valve with adjustable tappets at In and Ex.
2) 400 16 valve with shims at In and tappet adjusters at Ex' Also 3 cam lubes at inlet and 1 cam lube at Ex.
3) My VC 400 16 valve with shims at In and Ex. Also 3 cam lubes at In and 3 cam lubes at Ex.
I have a Manual that I downloaded from the net, but only show adjustment procedure and specs for In and refer me back to older model for Ex adjustment with tappet settings.
I need the specs and procedure for Ex cam valve settings with shims.
Can anybody help me with this.
Thanks
Paul
whitedevil
PostPosted: 09:36 - 13 Sep 2018    Post subject: Reply with quote
I have a Suzuki_GSF400_Bandit 91-97 manual if it helps.
https://www.dropbox.com/s/85ad4cgssagge7s/Suzuki_GSF400_Bandit_91-97.pdf?dl=0
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Paulcronje
PostPosted: 13:35 - 13 Sep 2018    Post subject: Reply with quote
Thanks for the Manual.
Page:11-19 GSF 400vv (97-model)
For inspection & adjustment of exhaust valve clearance, refer to GSF 400 Service Manual.(Paragraph second * on top of page.
EXHAUST VALVE CLEARANCE (cold) 0,20-0,25mm.
And then it's the Inspection & Adjustment Procedure for Inlet cam.
What is the specs for Lo side operating & Hi side operating at the exhaust cam.(Is the sub rocker arm play, Lo side clearance) and (Hi side clearance) the same specs from intake.
And, must I use Exhaust side valve clearance given on top of page, as the LO side clearance at Exhaust?
Thanks
Paul
The last post was made 5 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 17 - Page Size: 37.34 Kb
