Engines
chaza
PostPosted: 17:24 - 19 Sep 2018    Post subject: Engines Reply with quote
Hi guys
Can anyone tel, me if the direct bikes tommy db125, lexmoto tommy 125, yiying tommy 125, are interchangeable, I know most parts are the same, bug not sure if the engines are.
Thanks
Chaza
Riejufixing
PostPosted: 18:03 - 19 Sep 2018    Post subject: Reply with quote
I don't know, but: look on the crankcase, possibly below and to the front of the CVT cover, for a vertically flat area of the alloy casting that has a number stamped into it. That's your engine type.
chaza
PostPosted: 19:49 - 19 Sep 2018    Post subject: Reply with quote
Would the engines have different numbers, the db starts be I think, the yiying starts with zn I think, not sure about the lexmoto.
PostPosted: 20:02 - 19 Sep 2018    Post subject: Reply with quote
Yes they are
I did one up for one of me lads
https://www.bikechatforums.com/viewtopic.php?t=319432
and found
they're all made by the same Znen factory and only differ cosmetically.
They use the GY6 type engine
IIRC Some of them are called
YiYing Tommy
Lexmoto Valencia
DB125T
Tommy Retro
Aurora
Znen site
https://znenmotor.com/
chaza
PostPosted: 09:12 - 20 Sep 2018    Post subject: Reply with quote
That's what I suspected, my yiying has z rattle I suspect is small end, it's easier dropping a new engine then paying to have it fixed, but I'm not sure which way to go.
What issues might I have dropping in a db125, or even a lexmoto
Thanks
PostPosted: 14:39 - 20 Sep 2018    Post subject: Reply with quote
Have you checked the cam chain tension?
they're often neglected
chaza
PostPosted: 18:22 - 20 Sep 2018    Post subject: Reply with quote
No I haven't checked the cam chain, the noise is more akin to starter clutch, of variate, the noise is more noticeable on the right by the stator, this suggests it could be the starter clutch, I haven't checked it yet.
Chaza
chaza
PostPosted: 15:21 - 22 Sep 2018    Post subject: Reply with quote
I had the clutch casing off, the variate seems to be noisy although the sound seems loud at the other side. In going to replace it and see if I'm right.
Thanks
Chaza
The last post was made 5 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 17 - Page Size: 57.24 Kb
