Jewlio Rides Again LLB |
Jewlio Rides Again LLB World Chat Champion
Posted: 18:43 - 27 Sep 2018 Post subject: Hot Hatch |
Considering a hot hatch. Will be a daily driver. Looking around the £4-5k mark. Civic Type R, Focus ST, etc being considered. Not as keen on the VAG offering, unless you can give me a very good reason why.
Alternatively, RWD and not a hair dresser car.
What say BCF? ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
A100man |
A100man World Chat Champion
weasley |
weasley World Chat Champion
MarJay |
MarJay But it's British!
BenR |
BenR World Chat Champion
Musketeer |
Musketeer World Chat Champion
A100man |
kgm |
kgm World Chat Champion
Riejufixing |
B5234FT |
B5234FT Brolly Dolly
Sister Sledge |
DrSnoosnoo |
DrSnoosnoo World Chat Champion
Big Jock |
Big Jock Renault 5 Driver
Riejufixing |
A100man |
A100man |
t121anf |
t121anf World Chat Champion
B5234FT |
kgm |
grr666 |
grr666 Super Spammer
Riejufixing |
Shaft |
Shaft World Chat Champion
Posted: 23:05 - 28 Sep 2018 Post subject: |
Riejufixing wrote: | Jewlio Rides Again LLB wrote: | Brother in law had a GTi that bounced a load of valves due to the water pump and cam belt being linked somehow? One collapsed and took the other with it, from distant memory. |
Sounds as if it could be a maintenence issue. I think, although I'm not sure, that cambelt/tensioners/water pump simultaneous replacement is advised. Anything with an interference engine will have a bad time if the cambelt lets go. However, as I say, it's up to you what you like, but I wouldn't discount a whole type because of one perceived issue though! |
Where it's driven by the timing belt, it's recommended that you change the water pump when you change the belt, the main reasons being, the added pressure of a new belt can cause the old WP gasket to fail and you have to take the belt off to change the pump, so if you do both at the same time, there's no additional labour involved.
As service intervals get ever longer, so the strain increases on these low value products; I've known water pump bearings to fail well ahead of the belt change interval, which releases enough pressure on the belt that the tensioner can't take up, resulting in a big bang.
Equally, I had a customer have a belt failure 25K early, that cost him the thick end of £4 grand.
If you go by manufacturer's recommendations, its not about poor maintenance, it's about factory built in obsolescence. ____________________ Things get better with age; I'm close to being magnificent........
The last post was made 5 years, 184 days ago. Instead of replying here, would creating a new thread be more useful? |
