Fuel tap/pipe confusion
stirlinggaz
PostPosted: 15:36 - 29 Sep 2018    Post subject: Fuel tap/pipe confusion Reply with quote
Hi all,
Today i decided it was time to put the wee tdr back together.
Easy i thought, just refit the plastics, fuel tank & a couple of bulbs.
Problem? I have forgot which hose goes where, at the tap & tank Embarassed
I did take pics with this fancy new fone but technology has got the better of me as i can no longer find the relevant pics (that'll teach me as masking tape and a biro usually suffices)
So im now at the confused stage & the more i think about it, the more confused im getting.
Help?
The fuel tank has 2 connections (helpfully not marked) with a small hose coming off 1 of them but i don't know where the other end goes...
The fuel tap has 3 connections marked '0' '1' and '2'
Theres a hose coming off '2' but dont know where the other end goes...
The carb has 1 main fuel line, but i dont know where the other end goes.
Anyone care to advise?
I'd attach pics but havnt figured out how to make them small enough Embarassed
cheers,
GAZ
jaffa90
PostPosted: 17:23 - 29 Sep 2018    Post subject: Reply with quote
I have never seen a fuel tap with 3 connections marked '0' '1' and '2'.
I have seen a fuel tap with a pipe going to the carb and a vacuum pipe going to the carb inlet manifold.
I have seen a tap with 3 positions as in on.off. and pri.
stirlinggaz
PostPosted: 17:54 - 29 Sep 2018    Post subject: Reply with quote
Hi,
Maybe the 1st 2 things your referring to are same thing?
Fuel tap has 3 positions on FRONT marked 'ON' 'OFF" & 'RESERVE '.
There are 2 connections on the right & 1 on top (maybe the vacuum pipe?)
but on the BACK of the fuel tap, the 3 connections are marked 0, 1 & 2 (this being the top one)
That make it any clearer?
cheers,
GAZ
jaffa90
PostPosted: 18:12 - 29 Sep 2018    Post subject: Reply with quote
Is this yours?
jaffa90
PostPosted: 18:15 - 29 Sep 2018    Post subject: Reply with quote
Or this,
stirlinggaz
PostPosted: 19:30 - 29 Sep 2018    Post subject: Reply with quote
jaffa90 wrote:
Or this,
Neither....
From the front it looks like the 2nd pic.
Bur when you take the tap off the bike & look at it from the reverse, it looks a bit like the 1st pic as it DOES have 3 connections
But sussed it anyway Very Happy
Theres a lot to be said for just walking away & going back to it with a clear mind.
Once i approached it in a more....simplistic way, it all came together.
There was really only 1 way it would go, based on the length of the hoses (f*ck the theory behind it all which i was initially trying to get my head round)
cheers,
GAZ
The last post was made 5 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 50.6 Kb
