kramdra |
kramdra World Chat Champion
Moxey |
Moxey World Chat Champion
Posted: 22:19 - 09 Oct 2018 Post subject: |
Snap! got mine 2 week ago.
https://i.imgur.com/ytCOvfb.jpg
Don't really think they're 'old' man bikes, maybe middle aged
I'd recommend fitting a voltmeter, I got one off ebay thats supposed to be waterproof (yet to test), mounted something like this.....
https://www.vfrdiscussion.com/uploads/1185263231/gallery_11167_3227_7230.jpg
I wired it in using a fuse tap saves frying a battery and melting wires when the reg/rec inevitably fails (unless its already been upgraded to mosfet and the wiring harness to boot). ____________________ Current: 02 FZS 1000 Some Bike Pics...
'I was too busy paying attention to pay attention' |
ADSrox0r |
ADSrox0r World Chat Champion
MarJay |
MarJay But it's British!
ADSrox0r |
kramdra |
Posted: 15:32 - 10 Oct 2018 Post subject: |
Red looks a fuck ton better
Disagree about the reg - stator will be a seperate failure, often noticed at the same time. Recommed:
Oil change.
Check wiring - remove the redundant and often melted connector between stator and regulator.
Fit a dual temp/volt meter. Commuting in winter it is nice to know air temp.
Get stator cover off (10 min job, new gasket) and check for oil sludge/ heat marks on insulation. If it looks bad, multimeter out and measure it.
Used, perfectly good, low mile stators should be available at a resonable price.. 20 quids.., so not a massive problem, may be a shared part with other bikes, cbr6?
Where as the regulator costs atleast twice as much. Do not replace unless it is faulty. |
trevor saxe-coburg-gotha |
Posted: 18:32 - 10 Oct 2018 Post subject: |
trevor saxe-coburg-gotha wrote: | What's the consensus on the first gen EFI viffers? Iirc they're heavier. But is build quality still amongst the best? And what's the fuelling like? I instinctively prefer carbs - but have definitely ridden EFI bikes that have fantastically smooth mapping. And I do like the idea of not having to worry about carbs gumming up or just suddenly going weird. Then again, I hate the check engine light style shit that comes with fuel infection. There's an early EFI bike for sale locally - though blue - and I've been tempted several times. That said, I also know a guy selling a decent red carb'd one for two grand - which is too much. Price is justified on the grounds that it comes with a crap load of luggage (which tbf is decent hard stuff), plus stainless system to fit, and sundry other bits and bobs. I just wish he'd offer it for 1500, and split the detritus - but he's not gonna. |
Early EFI 800s still have gear driven carbs - tick
They also have 20 year old linked brake systems - Hmmm. But probably more effective than the 2-pot sliders on the 750's
On anything that old, I'd budget for a comprehensive brake service and a complete re-spring unless it's already been done.
Fitting PR4s has made my 750 into a different bike.
Fairing on the 800s can be a bit of an arse to dismantle due to seized well-nuts but any tidy examples have probably had this shit sorted out by now, they will have been undone and reassembled with plenty of anti-seize.
Oh yeah. The flexible PCB on the clocks can rot. Utter bastard to get at, never mind fix. The digital section tends to go haywire first on the 800s.
IMHO, the best one was the 1st gen 750 with the standard swingarm which was an engineering marvel at the time and was one of the best things out of japan. A white one for preference. However, they are seriously old now so there is a chance of terminal rot and unobtainable spares. As well as an obsolete wheel size. So best bet for me would be a late 750. First time you remove the fairing, you'll see why. It's the last bike Honda made that was DESIGNED to be worked on. Some of the fairing bolts have a torx inside a hex so if you round out the allen head, there is still a secondary fitting to use. They have 3/8" access holes in the subframe for socket extension bars to remove the shock and screwdriver holes in the chassis to allow access to the carb drainscrews and those dzeus fasteners. Lovely stuff. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ADSrox0r |
MarJay |
Posted: 08:51 - 11 Oct 2018 Post subject: |
The earlier EFI models are lighter than the VTEC models, which is why I bypassed so many listings for VTEC (well, that and the servicing). I think the difference is about 10kg. VTEC models also don't have gear driven cams.
Mine cost £1600 with top box, GIVI wing rack and two GIVI monokey panniers. The FI is smooth and I don't notice any flat spots or hesitation. It's the smaller engined bikes that suffer more from this I think, especially before the first lots of Euro emissions gubbins came in.
Even with the issues it has, it's a LOT of bike for the money. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
myvision |
myvision Scooby Slapper
ThatDippyTwat |
MarJay |
Posted: 09:37 - 15 Oct 2018 Post subject: |
myvision wrote: | Are these as good as they say?
I've been offered a 98 model as a swap for my Hornet.
It's got over 50k on it what should I be looking for when I view it?
MarJay how is it in heavy London traffic? |
Head Bearings
Check Regulator Rectifier has been replaced with MOSFET one
Check the brakes work well, as they are a massive faff to overhaul.
It's not bad in traffic. Even though it's a hydraulic clutch I find it a touch heavy in town. Other than that, the bike is actually surprisingly good to maneuvre through traffic. The steering lock is good, the weight is carried low so it doesn't feel unwieldy (My Street Triple feels worse because it carries all it's weight high which is good for track work, but not so good for pootling along slowly). It's not the perfect town bike, but I have 2/3rds motorways to consider which is why I wanted a full fairing and a fair bit of power. If I was just commuting in town I'd probably have gone for something smaller, lighter and narrower like a big single road bike or a CB500 or something.
I got the Haynes manual at the weekend and it's pretty damn complex. It's probably 1/3rd bigger than the VFR750 manual I had, and some of the easiest tasks are more difficult on this bike. I don't mind too much as I am a half decent mechanic, but I can see why it would put some people off. The linked braking system is simply stupid. Why anyone would consider this better than a pair of 4 pot nissins on the front and a two pot rear I have no idea. Three pot sliding nissins aren't great at the best of times, but to have different pistons controlled by different brake controls? Absolute madness.
The one saving grace is that unlike my 600RR they aren't Tockicos! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
MarJay |
Posted: 12:01 - 25 Oct 2018 Post subject: |
So I'm part way through my third week of using this bike to commute to London and so I thought I'd post up a few more of my thoughts on the bike now I've got a bit more used to it:
It's a gentleman's express. It's comfortable, but it can go reasonably quickly. Motorway is probably where it is happiest. It does go around corners but it does it in a kind of grumbly way. Like an old fighter who has proven himself over his life, and doesn't want to fight but will do it when pressed. it doesn't feel wayward in corners, just unwilling which I think I prefer to too twitchy or too stable.
I'm getting about 54mpg, around 200 miles to reserve which isn't too bad I don't think.
How I load the top box is critical. If I don't ensure all of my gear is sat as low as possible in the box, the front end becomes twitchy and it tramlines badly when filtering. It's almost dangerous when it's like this, but by seating my bag as flat as possible into the top box and making sure my disc lock sits against the base of the top box, I can almost completely elmimate it. Ironically it's twitchier since I had the head bearings adjusted, but the rattle is gone and it does corner better. There is no longer a 'no mans land' between accelerating and braking.
The clutch is HEAVY but you don't need to slip it as much as on, say, the street triple. You can let out the clutch at 2000rpm and trickle along fairly happily. I've ordered an Oberon clutch slave cylinder because it currently slips and makes a graunching noise if you pull away too hard when the bike is not completely hot. I'm told this is the clutch pushrod, so I figured a lower effort slave cylinder would kill two birds with one stone.
The engine is weirdly smooth and yet vibey. It has tingling vibes through the left hand footpeg sometimes.
I accidentally wheelied it on the way home the other day. Just a few centimetres above the tarmac, but nevertheless I did. Perhaps the top box was overloaded! I haven't even done this on the Street Triple! It wasn't even off the clutch (which does slip a bit... see above), it was simply through a hard opening of the throttle.
The engine power is linear, but it does make some power. You can go quick if you want, but it's not quite as exciting or dramatic as the Street Triple, and it's not quite as grunty or deep sounding as the Buell. It's not as dull as my old TT600 though, which actually surprises me. I've avoided fully faired bikes because of that, and now I'm not so sure I was right.
The Dual CBS is totally stupid. It gives no benefit, adds unnecessary weight, forces the use of what are effectively 2 pot sliding calipers and makes maintenance complicated. It barely stops the bike anyway even though I did a pretty thorough brake overhaul last weekend. Don't get me wrong, they work and the Dual CBS is not intrusive but I can't see how it's better than other braking systems that are actually able to stand bikes on their nose. Especially to an experienced rider. Honestly I'd rather have an ABS equipped bike with conventional unlinked brakes, and for me that's saying something. With decent brakes the bike would be a pure pleasure to ride, as it is you have to do a LOT of planning ahead, especially on the motorway. Whoever insisted that this bike have Dual CBS is an idiot. So many areas are so much better than other bikes and it's just let down by mediocre complex overengineered brakes. Maybe some of the poor braking is down to weight? If so this is pretty much the only area that an excess of bulk is really an issue in day to day riding.
The dash is excellent, the air and engine temperature gauges are useful, the fuel gauge works and I've now got used to the tiny speedometer after being used to the large digital LCD on the Triumph. It's not a bike that urges you to seek the top end of the rev range, and seems a little bit gruff and grumpy when doing so (see above) but when you do it does move you forward... not fast... but with some small level of urgency shall we say? It's quite flat for a reasonably modern 800cc four. It should probably have at least another 10, maybe even as much as 30 more horsepower.
It was a good buy. For what I'm doing with it, it's pretty much ideal. If it had better brakes it would be a masterpiece IMO, but as it is it's just a good bike. In terms of bike per £ it's fantastic. I spent a bit on new chain and sprockets and having the head bearings tightened, but it's still good value. I'd have probably had to spend similar money on any bike I bought for this job.
{edit} It's familiar. I wondered why certain aspects of the bike just seemed 'right' to me, and then I remembered how similar it should be to my first 'big' bike, the VFR400 NC21. The comfort is similar, the riding position not far off, the power delivery is also similar and it has a similar character. It definitely has a bit of character, unlike say a CBR600F, but it's not an interesting character like a Buell or the Street Triple. It's a little bit too competent for any of that really. I suppose it's not a bad thing, and it makes it better for the use I have for it, but it means that as an only ride it would be very easy to be tempted away to madder or more practical or more comfortable bikes depending on your weapon of choice. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Robby |
Robby Dirty Old Man
MarJay |
Robby |
Robby Dirty Old Man
MarJay |
The last post was made 5 years, 183 days ago. Instead of replying here, would creating a new thread be more useful? |
