Steering column won't come out?
Zakalwe
PostPosted: 22:14 - 07 Oct 2018    Post subject: Steering column won't come out? Reply with quote
I'm trying to remove the entire front fork assembly / steering column from one Gilera DNA and move it to the other. Looking at diagrams like this here https://www.easyparts.nl/showdrawing/12441/109526/525/0-4019-1-m415-m363-m6259-m12441-s12447-d109526/Fork-steering-tube---Steering-bearing-unit.html we've removed every possible bolt keeping it in, and watching people disassemble steering columns on youtube, it should just slide right out, but it won't. we tried hitting the top with a hammer incase it was just lodged but it's definitely not just stuck in from age.
Anyone know what we're doing wrong?
Riejufixing
PostPosted: 22:27 - 07 Oct 2018    Post subject: Reply with quote
Photos of what you have.
Teflon-Mike
tl;dr
PostPosted: 22:47 - 07 Oct 2018    Post subject: Reply with quote
I imagine you have taken off the top nut that holds the top yoke in place, but NOT the nut beneath that puts the pre-load on the bearings, probably because it dont look like a nut, it'll be a sort of ring with six or eight slots in it, that needs a special spanner or C-spanner to undo....
Oft chewed to bludgery by folk without a slot-spanner or suitable C-Spanner trying to undo it with a hammer and chissel or similar.
Beneath them is the bearing races, and if the steering stem actually moves side to side like steering the forks... it aint 'stuck'.. there's something, likely the castle but under the top yoke still holding it in...
WHEN that comes out.... get ready to catch the loose balls! It usually goes as an avalanche.... new bearings required... cos sods says you will find all but ONE of the old bearing balls... whether they were salvageable or not!
A Haynes diagram or an exploded parts microfishe IF you really are a cheap-wad, in ENGKISH I find also helps.... especially when working on latin-loverlies, where the manuals tend to be left in the native italian!
PostPosted: 22:51 - 07 Oct 2018    Post subject: Reply with quote
I think Mikes refering to the Balhoofdborgmoer
not to be confused with the Balhoofdmoer
You do know the Balhoofdlager is probably a tapered roller?
and if its bitten into the stem, will need removing first, especially
if it was tight to begin with and walloped on with a tube.
Zakalwe
PostPosted: 00:20 - 08 Oct 2018    Post subject: Reply with quote
Thanks for the quick reply. Will post a photo in the morning in the sunlight.
We got the C-spanner nut off fairly easy with a couple flathead screwdrivers and hammers hitting it in each direction, no wrecking of it.
seems this is where we are it, we followed these instructions and yet like I say the center just won't come off the main frame, doesn't seem to be a way to get the bearings out if they need to come out first.
https://imgur.com/a/ZcJeJyY
PostPosted: 01:23 - 08 Oct 2018    Post subject: Reply with quote
have you tried setting fire to it?
Zakalwe
PostPosted: 10:47 - 08 Oct 2018    Post subject: Reply with quote
https://imgur.com/a/xRSRIvi pic
Riejufixing
PostPosted: 12:33 - 08 Oct 2018    Post subject: Reply with quote
Could just be tight. I take it you're not trying to salvage the bearing? You could try warming it up.
Zakalwe
PostPosted: 14:19 - 08 Oct 2018    Post subject: Reply with quote
I would like to keep it sure as I don't have a replacement. which part should be coming out from which exactly? like I say we've tried giving it a whack through cloth, tried prying the bearing ring off with a screwdriver / small allen key, do the forks need to bee out / weel off maybe?
Riejufixing
PostPosted: 14:59 - 08 Oct 2018    Post subject: Reply with quote
Hm, difficult. The harder & sharper you hit the thing the more likely it is to damage it, and the hotter you get it ditto. The stem should slide down through the inner race. If you warmed the whole lot up to (say) 250C then cool the stem and hit it, you might find it will come a bit easier. It could be the bottom bearing sticking.... yoi might find it comes off easier if you remove the dead weight of the forks, also.
To help prevent damaging the threads, put the nut onto the threads. Use a soft drift, e.g. a piece of aluminium or brass on top of the stem to hit. You should be able to read the bearing size off the markings on the outer race (other side?) if they're U/S.
PostPosted: 15:00 - 08 Oct 2018    Post subject: Reply with quote
The forks and wheel are still in? are they touching the floor? If so, that'll be your problem!!
Riejufixing
PostPosted: 15:05 - 08 Oct 2018    Post subject: Reply with quote
No! They can't be, can they?! Surprised Shocked
Zakalwe
PostPosted: 15:26 - 08 Oct 2018    Post subject: Reply with quote
Yes, like another poster suggested, we put the main nut on the stem and covered it with a cloth, while one of us lifted the bike up off the floor and the other gave it a good whack - it wasn't coming out so we thought the bearing ring must have to be taken out with a special tool or something, but watching youtube videos it should just slide out at this point so we're kinda stumped.
Was planning to 'simply' swap the entire front fork/headlight assembly between two DNAs, always some kind of issue isn't there?
PostPosted: 23:22 - 08 Oct 2018    Post subject: Reply with quote
I stand corrupted, that's not tapered rollers
cb1rocket
PostPosted: 08:52 - 09 Oct 2018    Post subject: Reply with quote
just take the wheel and forks off, be so much easier!
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
The last post was made 5 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 17 - Page Size: 91.58 Kb
