Seized wheel locknut (CAR)
Andy_Pagin
PostPosted: 12:05 - 17 Oct 2018    Post subject: Seized wheel locknut (CAR) Reply with quote
Ford Explorer with alloy wheels.
It's a nut screwed onto a stud, the 'key' fits into the nut a bit like an odd shaped Allen key if that makes sense. No matter how hard I push it in place with my knee it slips out when I turn the nut.
So what's the best way of shifting it? I don't think heating the nut would help as that would just loosen the fit of the key even more.
So far I've tried a Steelson wrench which can't get a grip, tapping the wheel/nut with a club hammer to try and loosen it, doing up the other nuts extremely tightly to get the load off of it, all to no avail.
Any ideas what I should try next?
Yamaha Vity -> YBR125 -> Fazer 600
rpsmith79
PostPosted: 13:02 - 17 Oct 2018    Post subject: Reply with quote
Sometimes you can get away with hitting a "slightly" oversized socket onto it, but will more than likely destroy the socket in the process
As a last resort, try ringing round your local tyre fitters, as most will have the ability to remove it for a relatively small fee, i think i paid about £15 last time i had to have a stuck locking nut removed due to a sheared key, luckily it was the last one i was removing as i was replacing them
Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet
Riejufixing
PostPosted: 13:17 - 17 Oct 2018    Post subject: Re: Seized wheel locknut (CAR) Reply with quote
Why can't your Stilsons get on it? Recessed?
Andy_Pagin
PostPosted: 13:56 - 17 Oct 2018    Post subject: Re: Seized wheel locknut (CAR) Reply with quote
I can get the wrench on it, but the end hits the wheel rim so it's not straight on and won't grip tight.
Riejufixing
PostPosted: 14:13 - 17 Oct 2018    Post subject: Reply with quote
Can you get a bench vice on it and use that for levering?
PostPosted: 14:13 - 17 Oct 2018    Post subject: Re: Seized wheel locknut (CAR) Reply with quote
Put try putting tape/paper or similar round the edge to pack it out a tiny amount to get a tighter fit.
Andy_Pagin
PostPosted: 14:30 - 17 Oct 2018    Post subject: Re: Seized wheel locknut (CAR) Reply with quote
Genius! I'll try that.
Hong Kong Phooey
PostPosted: 14:34 - 17 Oct 2018    Post subject: Reply with quote
https://www.screwfix.com/p/laser-locking-wheel-nut-remover-2-pack/1889j
There's also sockets that adapt to the shape of the nut, e.g. Gator Grip.
No matter how you get it off, bin the locking nuts and put standard ones on. You'll thank me next time. Thumbs Up
CBR600F4
rpsmith79
PostPosted: 14:38 - 17 Oct 2018    Post subject: Reply with quote
These are good, but you need an air/impact wrench to get them to work with any level of success, it would be very difficult to get them to bite using a breaker bar or similar
recman
PostPosted: 16:52 - 17 Oct 2018    Post subject: Reply with quote
Plusgas?
2010 Street Triple, you know, the cool one with the round headlights.
alt tab - 'In order to offer any decent advice, we need to see pictures of her tits.'
paddy - 'Settle for nothing less than twin underseat pipes and round lights, anything else is inferior.'
Old Git Racing
PostPosted: 21:48 - 17 Oct 2018    Post subject: Reply with quote
Get a torqx bit that is slightly too big and hammer it in. Use a breaker bar on it and go for it all or nothing. Dont be gentle.
OGR.
Yamaha 350 YPVS x 2. BMW R1150R. Random bits of mates broken bikes.
bikenut
PostPosted: 10:40 - 18 Oct 2018    Post subject: nuts Reply with quote
simialr experience on an almera, the lad "lost" the special undoer....use stillsons but they wanted to slip on the chrome surface, but they all came off all ok.
How are you getting on??
if still stuck, post a pic so we can see what your up against.
All the other "nuts" on that wheel are all still up tight, yes ?
nuts about bikes
Andy_Pagin
PostPosted: 12:04 - 18 Oct 2018    Post subject: Re: Seized wheel locknut (CAR) Reply with quote
It worked eventually, folded kitchen paper four times and hammered it in, then full body weight against it and a big breaker bar.
dydey90
PostPosted: 14:59 - 18 Oct 2018    Post subject: Reply with quote
If you need to do it again (or if somebody in the future is reading this) it also helps to use penetrating oil like Plusgas, lump it a few times with a hammer and try heating the bolt with a blowtorch.
As above though, Iíve come across similar situations and used the torx bit method with great success.
Precision & Measuring Tools
£39.99 - Buy It Now
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 2.61 Sec - Server Load: 1.97 - MySQL Queries: 16 - CDN Objects: 43 - Page Size: 84.45 Kb
