Any Openreach engineers here?
PostPosted: 21:40 - 17 Oct 2018    Post subject: Any Openreach engineers here? Reply with quote
So, the new house has a drop wire from the pole, through a window, to this.
https://cdn.bcf.44bytes.net/files/bt_52a.png
The service isn't live yet and won't be for a month or so, but the window needs replacing, which means the incoming wire has to be moved. The internal wiring leaves a lot to be desired too, and I only need one master socket anyway for the broadband. I'd like to run the internal wiring in a channel down the wall then plaster over it, rather than having a crap cable clipfest.
Nearly every thread I've found deteriorates into an OMGWTFNOTLEGALTHINKOFTHEKITTENZ! outpouring, since it's "not my property". I've not found however any evidence of anyone being carted off by the popo to work in a BT call centre for the rest of their life.
What is the actual likelyhood of having my back doors kicked in if I were to replace and relocate this junction box, and wire my own master socket?
Hawkeye1250FA
PostPosted: 21:48 - 17 Oct 2018    Post subject: Reply with quote
This is exactly the kind of thing that doesn't need s question on a forum. 👍
If you have the skills to do it - do it. 😁
PostPosted: 22:32 - 17 Oct 2018    Post subject: Reply with quote
Not looking for permission, more interested in hearing first hand experience of anyone falling foul of the "you no touchee" rule.
carvell
Scuttler
PostPosted: 22:38 - 17 Oct 2018    Post subject: Reply with quote
I wouldn't hesitate to move it. I've replaced master sockets before and shifted stuff about without a second thought. Whenever BT turn up to fix unrelated issues they don't bat an eyelid.
The only thing I'd say it make sure you do a decent job of it, using decent crimps etc. so that it looks like it could have been done by BT.
Doubt you'll find anyone that's ever got into hot water over it.
Yamaha TDM 850
stevo as b4
PostPosted: 23:06 - 17 Oct 2018    Post subject: Reply with quote
^ What he said. Get rid of that nasty 1960's corrosion prone broken box and run new single core internal cable to a new Openreach socket. Keep wiring simple and don't connect loads of extension wiring if you don't need them. Obviously keep any junction box's away from Windows and places where you can get damp or condensation.
UnknownStuntm...
PostPosted: 09:27 - 18 Oct 2018    Post subject: Reply with quote
I am that soldier. BT box was in almost in the centre of my poxy 2 bedroom terraced house, above the skirting of a wall with no sockets in and a door either side. So either way I'd have needed to run a cable over a doorway. So I moved the BT socket to nearer the back of the house, where it came in originally, shortened the cable and tried it. Several attempts later when I had calls but no BB, I gave up and called ISP, who called BT in. Engineer came and told me 'we tend to find old houses have these boxes in the strangest places, and never where you've left them'. Then he remarked on the new cable clips along the skirting board. Then he got the fuck on with the job after having the best cup of tea in his life and we all lived happily ever after.
HTH Thumbs Up
UncleFester
PostPosted: 11:19 - 18 Oct 2018    Post subject: Reply with quote
We had one of those .... removed it. Cleaned up the incoming pair, crimped it direct to a new new cable that goes into a spanking newNT5e master socket.
Ours was so rotten that the wires had been touching and shorting out, slow electrical burns on the wiring stuffed in there.
ADSL went from .7mb down .1mb up to 7mb down .5mb up. 500+ disconnects a day down to 0 disconnects.
Now on fibre BUT if your last "half mile" of copper is all fucked up, your service will be shite no matter what you use.
remember - pins 2 and 5 only and do NOT connect the bell ( orange) wire as you do not need it. We only have one socket in here, that's it. No extensions, ripped it all out when i sorted out the original mess.
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
The last post was made 5 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.15 - MySQL Queries: 17 - Page Size: 60.48 Kb
