Problem with CDI and Regulator/Rectifier of Yamaha Virago 25
PostPosted: 08:11 - 23 Oct 2018    Post subject: Problem with CDI and Regulator/Rectifier of Yamaha Virago 25 Reply with quote
I'm just bought it yesterday, XV 250, i don't know how to wiring this CDI and Regulator/Rectifier, anyone can help me?
The CDI from Langfang Kokusan: D125-LK47 839349 42 06
It's not the original of XV250 so i don't know how to wiring this
Robby
Dirty Old Man
PostPosted: 13:50 - 25 Oct 2018    Post subject: Reply with quote
Assuming you have the right parts:
1. From the engine, 3 yellow wires go into reg/rec. These are the wires from the alternator.
2. The other wires from the engine - will probably be two or three different colours - go into the CDI. These are the wires from the ignition pickup coil.
3. The multi coloured wires from the reg/rec should plug into the wiring loom somewhere. This is the 12V DC electrical feed for the bike.
4. There may be another feed from the wiring loom to the CDI, which supplies power and sends a signal to the ignition coils.
tittymcarsefa...
PostPosted: 11:53 - 27 Oct 2018    Post subject: Reply with quote
A quick google search suggests the 250 uses the more common delta reg rec, yours shows a six wire unit however rather than the more common 5 wire, three will be power into the reg rec from the stator, one will be aground the other two are likely power out.
the bigger virago often use (iirc) a five wire single phase full wave reg/rec with a five pin plug, they are not wired like a delta wave unit.
The type of cdi unit must match the bike so ensure the spark timing is correct otherwise you could suffer engine damage.
It is possible to wire alternative cdi units but I would advice not to attempt if you don't know what you are doing.
The last post was made 7 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.68 - MySQL Queries: 14 - Page Size: 35.14 Kb
