Calumh96 |
Calumh96 Two Stroke Sniffer
WD Forte |
WD Forte World Chat Champion
Calumh96 |
MarJay |
MarJay But it's British!
WD Forte |
Calumh96 |
Posted: 20:27 - 30 Oct 2018 Post subject: |
I dont have the pipe and id have no idea where it was supposed to be on the inside of the tank let alone be comfortable opening op the tank and resealing it |
Riejufixing |
Calumh96 |
Posted: 20:33 - 30 Oct 2018 Post subject: |
To be honest i dont know what it looked like before this fault occurred, if anyone has the EFI and could compare that would be great. When i look into my tank i just see a hole in the middle i was advised that there was supposed to be a fuel breather there. I never had any reason to look inside of my tank before this issue |
Riejufixing |
Calumh96 |
WD Forte |
Calumh96 |
WD Forte |
Riejufixing |
Riejufixing |
WD Forte |
Calumh96 |
Riejufixing |
Posted: 22:22 - 30 Oct 2018 Post subject: |
So get your bit of Nylon tube, get tank off, empty, push tube up through the cleaned (inside!) remaining stub of tube on bottom, when about 2.5cm to go, smear the sides of the exposed nylon tube with Araldite, continue to feed the tube in ensuring Araldite is continuously drawn into the metal tube as the Nylon one feeds in, allow to set, snip off Nylon tube, reassemble.
Or take it to someone who can braze a new piece of pipe in (ask for an estimate of cost first!), or buy a new/2-hand tank. |
Calumh96 |
Posted: 09:08 - 01 Nov 2018 Post subject: |
Riejufixing wrote: | So get your bit of Nylon tube, get tank off, empty, push tube up through the cleaned (inside!) remaining stub of tube on bottom, when about 2.5cm to go, smear the sides of the exposed nylon tube with Araldite, continue to feed the tube in ensuring Araldite is continuously drawn into the metal tube as the Nylon one feeds in, allow to set, snip off Nylon tube, reassemble.
I've made the choice, i will order a new tank and attempt the repair once i have the new tank for educational purposes |
Calumh96 |
Posted: 15:16 - 04 Nov 2018 Post subject: |
So Lexmoto sent me a new tank for the old model
Curiosity killed the cat and i took my old tank off to get the snapped part out. Photos linked below. Unfortunately due to the angle there's no way to form a repair that doesn't involve splitting the tank open.
https://imgur.com/a/ZWSXEqg |
Riejufixing |
Calumh96 |
Calumh96 |
misscrabstick |
misscrabstick Crazy Courier
The last post was made 5 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
