Riejufixing |
Posted: 20:10 - 30 Oct 2018 Post subject: Steering head: taper rollers, press or mix and ??match?? |
Well, I've got a used bottom yoke (Rieju RS3) with stem that's got a taper roller inner on it. On these 125s, the bearings are real sods to get off, being hard up against the light alloy of the yoke and tight as hell, and I normally resort to pressing the whole stem 5mm or so through the bearing AND alloy yoke, then pressing it back in to the yoke, which leaves a gap between the bearing and the yoke, so I can get a puller on it.
I don't like doing this, from an "engineering" point of view.
Neither do I like the idea of keeping the inner race, and using it with an unpaired outer in the headstock.
Which is the lesser of two evils? |
WD Forte |
WD Forte World Chat Champion
Posted: 21:12 - 30 Oct 2018 Post subject: |
Riejufixing |
Hong Kong Phooey |
Riejufixing |
Posted: 22:03 - 30 Oct 2018 Post subject: |
Hong Kong Phooey wrote: | Hmmm, surface damage to the yoke would be characterised as cosmetic unless I'm missing something. Can it not be released with fire, puller (no gap huh?) or dremmel to slice it off the shaft?
If you're replacing bearings you want them to be in the best possible condition. |
There's no gap whatsoever, and the outer diameter of the inner race has a square (ground!) shoulder. Sodding things. I belted a 3/8" cold chisel into the non-existant gap on one yoke, didn't do that again, it shattered the chisel and took a lump out of the alloy.
I suppose it might be possible to destroy the cage, "Dremmel" a slot in the iner race or get at it with an angle grinder t'other way, and whack it with a chisel to crack it off, but, well, yuck!
Mmm. Angle grinder.
However, the inner race is OK, so I'd save money and time using it. Hm. It may not be the same make/spec/angle though. Blast. |
WD Forte |
Posted: 01:42 - 31 Oct 2018 Post subject: |
Pfft easy peasy
( am I the only on who gets pitchers on their interwebs?
See? nice compact 28K file size anorl, not 7 mega byte monstrosities)
https://imgur.com/X00SK7f.jpg
Fuck dremel, weak as piss and it would take an age plus loads of
those wee discs.
I'd get a 1mm cutting disc in the old angel grinder
clamp the rollers to keep em from spinning round
then make 1 or 2 easy does it angled cuts to get the rollers and cage off
wear eye protection, glubs n shit too or course!
Pay attention to and try to follow the circumference of the stem
whilst cutting to avoid serious damage to it
Next For the inner some more easy does it angled cuts, try to stop before
cutting into the stem, but a few wee scratches wont destroy it
you can buff it out later with oily wet and dry.
If you think you may want to remove the bearngs again in the
distant future you could cut two opposed channels for a drift/pin punch to run in from underneath when the bearing is off ____________________ bikers smell of wee |
Sister Sledge |
bikenut |
bikenut World Chat Champion
Hong Kong Phooey |
Riejufixing |
B5234FT |
B5234FT Brolly Dolly
bikenut |
kgm |
kgm World Chat Champion
MarJay |
MarJay But it's British!
bikenut |
bikenut |
Riejufixing |
MarJay |
Posted: 16:28 - 02 Nov 2018 Post subject: |
Riejufixing |
Hong Kong Phooey |
Riejufixing |
Posted: 21:34 - 02 Nov 2018 Post subject: |
Good Lord. I purchased that exact puller a little while ago. I used it to pull a main bearing off a 50cc crankshaft. The tool was destroyed in the process. I thought I'd left a rather critical review on Screwfix's site, but I cannot now find it.
Faults: Jaw angle far too steep. Jaws/"sharp edge" far too thick. Jaws and bolts apparently made of cheese, painted silver. had to be dressed with a file to get it under the bearing.
If you need a separator like that, I strongly recommend buying something else!
While it's possible that this puller might get the bearing off ( sort of doubt it) if the bearings & cage were removed (there is no way it would get under the bearing), the length of the stem prevents the use of most of these sorts of pullers unless they are fitted with longer connectors. |
bikenut |
Riejufixing |
MarJay |
Riejufixing |
Posted: 11:36 - 03 Nov 2018 Post subject: |
MarJay wrote: | You have to keep going because you can't mix and match bearings. |
This thread has wandered significantly off the original post, so I'll dump it, but some parts, like that, are still interesting.
Depending on the design (type of bearing and the manufacturer), some roller bearings have interchangeable components. This is the case for single row tapered roller bearings.
A quick poke about gets this, from Skef's website:
https://www.skf.com/uk/products/bearings-units-housings/roller-bearings/tapered-roller-bearings/index.html
SKF wrote: | Separable and interchangeable
Depending on the design, tapered roller bearings are separable and components of same-sized bearings are fully interchangeable. For example, single row tapered roller bearings are separable (fig. 5), i.e. the inner ring with roller and cage assembly (cone) can be mounted separately from the outer ring (cup). This facilitates mounting, dismounting and also maintenance inspection routines. |
The same goes for single row cylindrical roller bearings. |
The last post was made 5 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
