| Sweaty_Doughnut |
 Sweaty_Doughnut Nova Slayer
 Posted: 11:20 - 04 Nov 2018 Post subject: Oxford heated grips appears not properly installed |
Hi,
I've bought a PCX 2019 model, or 2018, whatever they call it. I have requested Oxford heated grips to be installed but it seems to be they are behaving strangely since they are too loose regardless if I tighten the throttle cable. I have attached the video. Basically, the throttle goes back to it's place and you can still close it further (you can see on the video how much further I can close it). I started the engine to test as well, when I release the throttle the engine is idling correctly, but that additional loose space is annoying. Do you have the same thing with the original grips or Oxford heated grips?
The video is on the link https://youtu.be/KrQC31Chhio |
| stinkwheel |
| Sweaty_Doughnut |
| stinkwheel |
 Posted: 14:16 - 04 Nov 2018 Post subject: |
The heated grip still has nothing to do with it though. It sticks onto the outside of the twistgrip mechanism.
Looking on ebay, at PCX cables, you have an open and a close cable. Both have an adjuster at each end. The nut itself is just a locknut to stop the adjuster turning. The adjustment is where the end screws into the housing ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cb1rocket |
 cb1rocket World Chat Champion
| Robby |
 Robby Dirty Old Man
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| Sweaty_Doughnut |
| stinkwheel |
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 23:37 - 05 Nov 2018 Post subject: |
| Robby wrote: | Yes, I'm currently trying to use their Hothands heated grips - the ones that wrap around the existing grips, because new bike is pretty.
The only slightly problem is that they've printed HI-OFF-LOW on the switch housing, but only put a two position switch in there, so the options are cold or painfully hot. This is my second set of them, and they're going back when I get round to ordering some heated gloves from Gerbing. |
Get the symtec ones that stick to the bars under the normal grips then. Only the littel bit of wire stickingout shows they are there at all. They also have high, off and low. Use the 6-pin, 3-position switch of your choice. Low they are in series, high they are in paralell. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 7 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
