| KenB1951 |
 KenB1951 Derestricted Danger
| kgm |
 kgm World Chat Champion
| bikenut |
 bikenut World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
 Posted: 20:47 - 02 Nov 2018 Post subject: |
Pitchers would really help you know
Its a simple affair
The RH frame holds the Rh taper bearing 17
and the SA has a spigot which locates in it
( 18s are the oil seals btw)
The left hand end of the S/arm holds the LH taper bearing 17 and the bolt 11
screwed through the lower LH frame fits in that
Screw in to tighten, out to loosen/remove
The bolt (11) has a 10mm hex socket and lock nut (16)on the outer and rubber cap (14)
If it isn't going in as far as did then its assembly error or wrong bearings
OR
You did remove the old outer race (17) from the RH frame cup (8) I hope?
(they can be a sod to remove)
If not, this will push the new bearing out by 10-12mm or so and even if you did
manage to fit the S/arm, it will be off line and also prevent the screw going in as far as it did.
Pitcher
https://images.cmsnl.com/img/partslists/honda-cx500-1978-england-rear-fork_bigma000165f24_f553.gif ____________________ bikers smell of wee |
| KenB1951 |
| kgm |
| WD Forte |
| kgm |
| KenB1951 |
| kgm |
| WD Forte |
| KenB1951 |
| KenB1951 |
| KenB1951 |
| KenB1951 |
| KenB1951 |
| KenB1951 |
| KenB1951 |
| WD Forte |
| bikenut |
| WD Forte |
 Posted: 13:49 - 05 Nov 2018 Post subject: |
The crusty looking one is just a pic grabbed ofn the interweb to show how deep the raceshould be in No8 its holder, it aint Kens.
In his pic, it looks very much like he's tapped in a new race(cup) on top of the old race/cup.
Ken.
Further examination shows you've probably done the same on the LH side too mate.
That bearing should sit deeper in the swinging arm than that and when the oil seal is fitted, it should be flush with the outer edge.
https://www.bikechatforums.com/files/573a8208-d014-4d2d-a61a-cbf91516bb55.jpeg
My advice:
Stop what your doing, clean it all down and remove those new races.
they may get damaged in the process
Then you have a choice.
Remove the old cups and fit new or take a chance and re use the old cups with your new cones
David Silvers want about £15 plus vat and postage for each bearing
(admittedly they're NSK and a quality make)
But
Those bearings are just a common 30202 (make a note of that number) and easily sourced.
For instance, simply bearings flog em for £3.68+vat upwards depending on quality ( budget/good/high)
https://simplybearings.co.uk/shop/advanced_search_result.php?sort=2a&search_in_description=0&keywords=30202&gclid=EAIaIQobChMIhvDemaK93gIVy7TtCh1fngUHEAAYASAAEgJBtvD_BwE ____________________ bikers smell of wee |
| kgm |
| KenB1951 |
| WD Forte |
| kgm |
The last post was made 7 years, 346 days ago. Instead of replying here, would creating a new thread be more useful? |
