| ajordan9 |
 ajordan9 Two Stroke Sniffer
| stinkwheel |
 Posted: 01:47 - 09 Dec 2018 Post subject: |
I would use and have used ATF, it is designed to take a real mechanical hammering over a variety of temperature conditions.
That said, I mostly use multi-grade fork oil now after having trouble losing damping effect on protracted, high-speed runs along bouncy roads. This was due to thinning of the damping oil due to excessive heat generation. The multigrade is less affected.
Of all places, halfords do a 5w-30 fork oil. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Snod Blatter |
 Snod Blatter Crazy Courier
| Pigeon |
 Pigeon World Chat Champion
 Posted: 19:08 - 09 Dec 2018 Post subject: |
I use Fully Synthetic Dexron 6 ATF (30 cSt@40c and 6 @100c). 151 Viscosity Index.
I've also used 0w20 engine oil (46 cSt@40c and 8.6 @ 100c) 168 VI
Done about 10k miles on each for a bikes around 200kg with stiffer springs and rider who's 100kg.
The damping using 0w20 made the ride incredibly comfortable. But fast turns were harder work.
ATF is noticeably harsher (but not any worse than a similar weight/vi mineral fork oil), but bike is livelier on the change of direction.
A 120KG CB125. ATF would be perfect.
What do you get from proper suspension fluid / oil. Well, in my a-little-knowledge-is-a-dangerous-thing mind, when it comes to mineral oil. Not much. Apart from very smelly oil after just 12 months.
Mineral fork oil has a low VI. So it starts out thicker and ends up a lot thinner (read crashy).
I've used Castrol, Fuchs and Motul mineral (and synthetic) fork oils.
I don't think ATF is any worse than mineral (in terms of VI) and its half the price.
What does really expensive suspension fluid get you. Very high VI (200-500 compared to 120-160).
So it is much more consistent from the moment you set off, to 3 hours later. Is it worth the cost, up to you.
£05 1L Dexron 6 Fully Synthetic ATF (30 cSt@40c and 6 @100c) 151 VI
£05 1L Petronas 0w20 engine oil (46 cSt@40c and 8.6 @ 100c) 168 VI
£10 1L Mineral oil (Motul Expert 10w 36 cSt@40c and 6 @100c) 112 VI
£23 1L Silkolene 05 Synthetic (43 cSt@40c and 9.5 @100c) 212 VI
Somewhat annoyingly, the better example can no longer be bought.
£?? Silkolene PRO RSF 10wt (47 cSt@40c and 14 @100c) 303 VI
It looks like Silkolene no longer sell their ultra high VI fork oil.
Got carried away. ATF is fine  |
| A100man |
 A100man World Chat Champion
 Posted: 17:01 - 11 Dec 2018 Post subject: |
Look out Teff.. you've got a challenger.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
The last post was made 7 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
