Deano4 |
Deano4 Derestricted Danger
Evil Hans |
Evil Hans World Chat Champion
Deano4 |
Pete. |
Pete. Super Spammer
Posted: 22:12 - 22 Nov 2018 Post subject: |
The sidestand switch doesn't matter if the neutral light is on.
You've jumpered the clutch switch so that's out of the equation.
If you jumper the solenoid manually it starts and runs so that's the run switch working.
Immobiliser or start button contacts IMO. Have a wiring diagram on me (It's for a k3/k4 but they must be very similar) ____________________ a.k.a 'Geri'
Deano4 |
Posted: 22:27 - 22 Nov 2018 Post subject: |
Pete. wrote: | The sidestand switch doesn't matter if the neutral light is on.
Immobiliser or start button contacts IMO. Have a wiring diagram on me (It's for a k3/k4 but they must be very similar) |
Yeh neutral light is on.
The reason I change battery is because it was on its way out and before I put new battery in the solenoid was clicking but just not enough juice to start.
I know before I changed battery the solenoid hit the frame of bike and sparked but don't think it would of caused any problems???
Could I possibly have a copy of the diagram?
I'm not great with electrics but If I knew where to put the meter on to to test I could rule out start switch. Strange it was all ok before fitting battery.
Thanks for advice |
bikenut |
bikenut World Chat Champion
Deano4 |
bikenut |
Deano4 |
Pete. |
Pete. Super Spammer
Posted: 20:38 - 23 Nov 2018 Post subject: |
Since the fault developed after you changed the battery check the heavy black lead from the battery making sure it's firmly fixed both ends. It will likely have a smaller wire split off it at the battery end, that wire will have a single spade connector part-way along it. Check that it's not corroded.
When you measure 11 volts at the solenoid where do you have the return - on the frame/engine or direct to the battery? Should be on the battery terminal.
Testing the solenoid is easy. Un-plug the left handlebar loom and find the yellow-black lead terminal (on the loom side). This is what feeds power to the solenoid from the clutch switch. Run a wire from Battery + to that terminal and the starter should crank over regardless of the rest of the switches. If it doesn't either the starter relay is fooked or the Battery negative circuit has a poor connection.
If it does crank try these tests:
Put your meter across the battery. Check the voltage, should be 12.6v or thereabouts. Now, follow the power to where it's dropping volts.
Red wire from the solenoid 30A fuse feeds the ignition switch. From the switch it's an orange wire feeding fuses 2,3 and 4. Pull the fuses and check the voltage at their feeding side, if it's significantly low you have a dodgy ignition switch.
Fuse 3 feeds the sidestand relay via a orange/yellow wire. When the stand is down OR the neutral light is on the relay feeds ignition power to the stop switch by a orange/black wire. The stop switch feeds the coils and the start button via a orange/white wire. Check the voltage at a coil if you can get at it if it's low you have a dodgy connection in the sidestand relay or the stop switch.
From the starter button a yellow/green wire turns into a green/yellow wire and goes through the clutch switch then turns black/yellow to the starter solenoid. ____________________ a.k.a 'Geri'
Deano4 |
jaffa90 |
jaffa90 World Chat Champion
Deano4 |
bikenut |
Deano4 |
Pete. |
Pete. Super Spammer
Posted: 19:07 - 26 Nov 2018 Post subject: |
To test the solenoid you simply run a wire from battery + to the black/yellow wire on the solenoid. If the starert fires the solenoid is working. If it doesn't fire either the solenoid is not working or you have a return fault. Return fault can be diagnosed by putting a jump lead from the starter housing to the battery negative. ____________________ a.k.a 'Geri'
Deano4 |
Deano4 |
The last post was made 5 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
