Motorhate |
Motorhate Nearly there...
Posted: 09:33 - 29 Nov 2018 Post subject: |
MCN wrote: | Ceramic Paste is the New Gloop for brake pads. 😎
BMW recommended part for car brakes.
I clean out the sliding areas of the calipers on my bikes and smear a smidgen of ceramic paste on the sliding surfaces of pads. Some where the piston pushes the pad too.
It was used mainly as an anti-squeal remedy. Steel to steel will chatter/vibrate/resonate in a disc brake system. Interrupting the vibration path limits the possibility of squeal.
Pads (some) now come with a plastic shim to prevent squeal.. |
Thing is, he says EBC recommend using copper slip on the pads when they actually say no such thing. I've never used any grease on a brake PAD as there's no need. It'll just attract dirt and dust and there's no need. Possibly on the pins that the pads slide on but never on the pads.
talkToTheHat wrote: | I think it's a bit harsh to have a go at dellboy for accepted practices* ? It's still done by Doncaster Motorcycles' Kev and Neil who frequently appear in (is it their own column or are they just media whores?) MCN's workshop warstories. And yes they're my local competent and freindly mechanics and I live in fear of finding my bike in MCN... |
Do they actually use it on the back of the pad or on the pins?
Quote: | But Dellboy advocates increasing preload until there is no sag becasue more preload means stiffer suspention. I call dangerous bullshit. |
Yes, this is the sort of shit that he comes out with that's downright dangerous. Another one was sanding off the chicken strips on a set of tyres - WHY OH FUCKING WHY?
Quote: | I make and heat treat my own inlay chisels, partly after watching delboy actually get semi-satisfactory results and having a high turnover of quite expensive fine chisels becasue of the nature of the work. I've not busted up a screwdriver that came with a decently tempered head, if I kill a screwdriver it's usually because it's made of something akin to chocolate rather than steel that can be hardened. |
There really is no need to do this if you buy good quality tools and use them for what they were designed for (in the case of chisels used on wood). Dellboy has a habit of using tools in a manner they were not designed for. His piece de resistance is putting an angle-grinder in a vice and using it like bench grinder, when in the background he has a bench grinder sitting on a bench? Why? ____________________ Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster |
MCN |
MCN Super Spammer
- Super Spammer
Monkeywrenche... |
Monkeywrenche... Nearly there...
rpsmith79 |
rpsmith79 World Chat Champion
Sister Sledge |
Posted: 11:30 - 29 Nov 2018 Post subject: |
I've been watching the Matt/Delboy saga for some time and the problem is Delboy appearing to sell out over time and start plugging some basically shite products. He started out as not too bad but his videos are nothing but cheap adverts. Any decent reviewer will point out bad bits as well as good bits - Delboy never has a bad thing to say and that should tell you all.
My problem is with safety and newbies not realising that things Delboy does can be incredibly dangerous and quite lethal. The Copperslip being just one example. Matt goes into great detail to explain the reasons why Copperslip is now not needed on most pads but also the engineering behind brake squeal and what the actual issue is - Copperslip is literally masking over a brake problem..
If we admit the truth to ourselves we'll accept that life can be and is shit. It can be very boring too. We goo for weeks sometimes and nothing exciting happens.
This YouTuber gets on my tits. She's leggy, blonde and attractive. Viewers care little about the actual content and just want to ride her.
Look at some footage - just about any of her videos will do. If you've ever been down to a gravelly riverbank and looked around, you'll know fine well that 'finds' just don't show themselves the way they do to her. Most of her stuff is fake and placed there. Dry finds on wet med where everything else is wet except her find. Stuff with no dirt inside or perhaps dry inside. The list goes on.
https://www.youtube.com/watch?v=s980MmUtAuk
Edit: The clean coin find at around 10 minutes is a prime example. ____________________ CCM 404 DS |
inline4 |
inline4 Nova Slayer
Motorhate |
MarJay |
MarJay But it's British!
M.C |
M.C Super Spammer
Motorhate |
MarJay |
Posted: 15:18 - 29 Nov 2018 Post subject: |
Motorhate wrote: |
Possibly, and apologies for being slightly misleading on that, but if you smear the back of a brake pad with grease then you'll be getting a false reading from these squeal shims. |
you're definitely wrong on that one, because the squeal shims don't go anywhere near the actual pads, they stick out of the caliper, and move with the pads so the end of the U piece touches the disc and then is moved back and forth with friction to generate the high pitched squeal.
I've always put copper grease on pads, and I'm pretty sure I have some genuine workshop manuals which reccomend it. Copper grease is used exactly for its high temperature properties, and you wouldn't use it in pretty much any other circumstance. The brake pistons should not have copper grease put on their sides, as it can attack the rubber seals. You can use red rubber grease however.
I've never heard of brake squeal being used as any kind of indicator of brake wear, except for these U shaped shims, which are basically pre brake pad sensors. I've certainly never heard of that related to motorcycles.
I agree that most of what your friend on Youtube says sounds to be nonsense, but in this case I think he's right.
It's also worth pointing out that a lot of brake pads have a T shaped key piece which slots into a groove in the caliper. Since these surfaces move in relation to each other, they will need lubrication, and as such putting copper grease on the edges of the pad backs especially on keying surfaces is a good idea. I've definitely encountered seized brakes which are basically down to dirt on these surfaces, and lack of lubrication.
So, whilst I get your incredulity, there are perfectly valid reasons to put copper grease on the metal backs of the pads, but obviously care must be taken not to get any on the friction material itself. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Baffler186 |
Baffler186 World Chat Champion
Motorhate |
Posted: 15:33 - 29 Nov 2018 Post subject: |
MarJay wrote: | you're definitely wrong on that one, because the squeal shims don't go anywhere near the actual pads, they stick out of the calliper, and move with the pads so the end of the U piece touches the disc and then is moved back and forth with friction to generate the high pitched squeal. |
Confusingly, the shims used to stop the rattle are called anti-squeal shims and they sit on the back of the brake pad. The springs you mention are clipped to the brake pads as per the below:
https://forum.ih8mud.com/attachments/dsc00948-jpg.510639/
Some brakes have a small metal part attached to the pad that acts as a wear indicator:
https://mikeduman.com/sites/default/files/blog_images/disc-pad.jpg
Quote: | I've always put copper grease on pads, and I'm pretty sure I have some genuine workshop manuals which recommend it. |
As I said, these will most probably be old workshop manuals. I'd doubt any manufacturer would recommend smearing copper grease on the back of a brake pad nowadays.
Quote: | Copper grease is used exactly for its high temperature properties, and you wouldn't use it in pretty much any other circumstance. |
Copper grease is widely used as an anti-sieze on bolts, in lieu of having not having any genuine anti-sieze.
Quote: | The brake pistons should not have copper grease put on their sides, as it can attack the rubber seals. You can use red rubber grease however. |
Agreed, although I never inferred that they should have copper grease on the pistons.
[youtube]It's also worth pointing out that a lot of brake pads have a T shaped key piece which slots into a groove in the caliper. Since these surfaces move in relation to each other, they will need lubrication, and as such putting copper grease on the edges of the pad backs especially on keying surfaces is a good idea. I've definitely encountered seized brakes which are basically down to dirt on these surfaces, and lack of lubrication.[/quote]
I'd disagree with that, especially as grease will only attract road dirt and dust. I have no problem with the pins that the pads move on being greased, by the actual pads IMO shouldn't have any copper grease on them at all.
Quote: | So, whilst I get your incredulity, there are perfectly valid reasons to put copper grease on the metal backs of the pads, but obviously care must be taken not to get any on the friction material itself. |
I really don't want to sound arsey and all self-righteous so I'll agree to disagree with you, mainly because quality brake pads usually have a lacquer already applied that will prevent the pots / pistons from sticking to the pads. ____________________ Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
MarJay |
MCN |
MCN Super Spammer
Motorhate |
Baffler186 |
rpsmith79 |
M.C |
M.C Super Spammer
Baffler186 |
Motorhate |
kerr |
kerr World Chat Champion
Motorhate |
Monkeywrenche... |
The last post was made 5 years, 150 days ago. Instead of replying here, would creating a new thread be more useful? |
