Nobby the Bastard |
MCN |
MCN Super Spammer
Nobby the Bastard |
MCN |
MCN Super Spammer
Posted: 22:44 - 28 Nov 2018 Post subject: |
'Traditionally' fuel level sensor systems measured current between the battery and the gauge with the sensor inbetween.
The sensor was a simple reostat (variable resistor).
Empty produced a high resistance and full provides zero resistance (effectively). The gauge was an ampmeter (Or voltmeter can't remember)
The simple test was to supply 12v direct to the gauge if it moved to full then it was ok.
Change the sensor.
More modern stuff maybe changes the physics. Some sensor systems use PWM (Pulse Wave Modulation) and are difficult for the uninformed to test. They almost always need at least three wires at the sensors.
The old stuff was Analogue and easy to test.
I don't know if any bikes use PMW.
I'd look on eBay for a sensor/float.
https://www.ebay.co.uk/itm/TRIUMPH-SPRINT-ST-1050-2004-2010-PETROL-FUEL-LEVEL-SENDER-USED-MOTORCYCLE/142997440633?hash=item214b4fc879:g:k7MAAOSwm4Zb2wWK ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Nobby the Bastard |
andym |
andym World Chat Champion
MCN |
MCN Super Spammer
Posted: 09:19 - 29 Nov 2018 Post subject: |
It's using a more precise magnetic sensor. The rubber ring will be acting as a proximity switch.
The ring has a magnet in it that closes reed switches inside the tube.
That will energise sectors on the gauge to indicate level.
It's a suck it and see thing maybe.
You may be able to determine the sensors functioning by measuring resistance as you move the rubber ring on the tube.
I could be talking out the hole in my area too.
This shower of pricks sometimes post some usefulness.
https://www.triumphrat.net/sprint-forum/245554-1050-fuel-tank-connections-help.html#/topics/245554
(***Beware*** Heavily Polluted by Murican Motorcycle Tossers.) ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Hong Kong Phooey |
WD Forte |
WD Forte World Chat Champion
Posted: 01:15 - 05 Dec 2018 Post subject: |
My theory guess
It uses a black pipe sender thing
Inside is a 'ladder' of changeover reed switches with resistors between them
dese fings
https://cdn-reichelt.de/bilder/web/xxl_ws/C300/MK23_90C2_01.png
As the magnetic float passes a switch it flips to the NO wire (signal)
and the combined resistance over the series resistors left in circuit
gives a voltage related to the fuel level.
the ECU read this volatage, translates it to fuel level and lights up
the appropriate leds
I reckon the sender is probably the bottom end of a voltage divider with a regulated voltage supply from the ECM.
If the magnetic float gets stuck or sticky , that will give erroneous readings
To test, you'd have to remove it and take resistance readings as you tip it upside down and back while watching the meter
I'd also read the voltage on the signal wire, if it's too low ( <5V)
that will give low fuel readings too.
Bad wiring and connections wil make it play up too ____________________ bikers smell of wee |
doggone |
doggone World Chat Champion
Nobby the Bastard |
The last post was made 5 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
