dsg10715 |
dsg10715 Derestricted Danger
MarJay |
MarJay But it's British!
stevo as b4 |
MarJay |
Posted: 20:46 - 30 Nov 2018 Post subject: |
stevo as b4 wrote: | If storing a bike over winter, I always drain the tank, the carb and run the bike with either the fuel turned off, or with the fuel tank removed until it stalls.
If I'm keeping the fuel tank on the bike, I'd firstly let it drain fully and then close the tap and either add 1/2cup of of two stroke oil and shake it all around, or spray half a can of water dispersant lube into it and do the same.
I don't buy the full tank and fuel stabiliser bollocks personally. I also like to try to use ethanol free fuel as much as possible. A two stroke will never start in 6months if you leave stale pre-mix in the carb to turn to gunge.
There's an argument for oil down the bores on a four stroke if not starting the engine for months. I don't usually bother, and with a two stroke the oily pre-mix will leave a nice film of oil all over the internals anyway. Some like to use a fogging additive or just run some 20:1 through the engine on tick over for 30seconds to oil everything. I never start a stored engine until it's time to get the bike out again. Monthly starts for 20mins of idling on the drive is a bike killer not a help.
But it's good to rotate the crankshaft a few times every month IMO just to stop the crank seals sticking, but again on a four stroke I'd not bother.
The most important thing on a stored four stroke engine, is to make sure you have oil pressure showing before you go to start it again. |
But Stevo, he's just said he's riding it every day!!!!
dsg10715 wrote: | to the fact that I do ride it regularly; |
He's not storing it, so I'm not sure why he'd want to drain the carbs. If he IS storing it, then why is he not following my advice anyway? *shrugs*. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
MCN |
MCN Super Spammer
dsg10715 |
MarJay |
MCN |
MCN Super Spammer
The last post was made 5 years, 146 days ago. Instead of replying here, would creating a new thread be more useful? |
