adengtg |
adengtg Scooby Slapper
Posted: 14:29 - 08 Dec 2018 Post subject: XJ600 fuel pump just wont work :( |
Hello everyone, ran into trouble and could use some help once again.
Ill put a little info at the top as to avoid as much confusion as possible.
The bike is a 1997 XJ600N. Uk model with electric fuel pump.
Bike was working fine when i bought it a few months ago and ive done nothing major related to the fuel system, electrics or engine. Only work ive done is putting restrictors on the inlet rubbers, replaced lots of mechanical parts (bearings, suspension etc) and tyres. Ive generally not touched the electrics.
Here goes:
Not really much i can say so ill just cut to the point. My fuel pump doesn't seem to be working. The OEM fuel pump was leaking on idle so i replaced it with an ebay "Direct replacement XJ600" pump which was a bit hit or miss it seemed, as in, it was very temperamental to when it would work (much like whats happening now).I put the OEM back on and was working again, clutch broke and bike is off the road so i left it there. came back to it a few days ago and fitted the new pump again and it wouldn't work. occasionally it would spray a bit of fuel out but then it would turn off again. put the OEM back on and that wouldn't work either. Occasionally, the pump(Either OEM or aftermarket) would work and the bike could start but after maybe 5-25 min it would run on 3 cylinders, then 2, then die and not start again.Occasionally i will come to the bike after leaving it a while, put in the key and start it up and it will work as normal.The pump is on for a few seconds and fills the carbs and the bike runs fine, the pump then occasionally ticks away to keep the bowls full and the bike is fine. then out of nowhere the pump decides its had enough and the carbs run empty. Tried to measure the output (V) of the two pin connector but couldn't get a reading as its too fiddly to get the probes in there. I then decided to rule out everything i could. I replaced all the fuses, fuel lines and replaced the fuel pump relay its self which has had no difference so far.
I've definitely got the fuel hoses the right way round and i've checked that fuel can actually flow through everything but at this point i'm out of ideas.
I'd really appreciate any ideas you guys have as to what i could check/try to get this running. AS always, if there's anything else you want to know that could help you i.e pictures or whatever i will do my best to get them to you.
Thanks very much for reading. |
Robby |
Robby Dirty Old Man
Posted: 17:13 - 08 Dec 2018 Post subject: |
Well either the pump is faulty, or the electrics are faulty.
There isn't much to the system in terms of electronics. The fuel pump relay supplies power to the pump when the ignition is turned on. This is a constant feed (usually).
The pump is a low pressure unit with a pressure sensor built in. If the pressure in the line is below x, it pumps. If the pressure is above x, it doesn't pump.
To test the pump:
1. Disconnect the pump outlet from the carbs, put it into a container.
2. Switch on the ignition. It should pump, and keep pumping.
3. Put your thumb over the end of the line and hold it there. After a little build up of pressure, it should stop pumping.
4. Take your thumb off the end of the line. It should pump again.
5. Repeat steps 3&4 until you're happy that it works.
I would probably do this test off a separate power supply - like a 12v battery wired direct to the pump, seeing as the wiring is also suspect.
If the pump behaves properly running off a battery, then the wiring is the next place to look.
1. Find a wiring diagram. Get familiar. There will be two main areas to look at. The feed from the main wiring loom to the pump relay, and the wiring from the relay to the pump.
2. Find the earthing points. The wiring to the relay probably uses a main frame earth shared with lots of other circuits. Even so, find it and clean it up.
3. The pump may have its own earth point. If this is heavily corroded, or the wire looks knackered, clean up the earth and/or replace the knackered wire.
4. If all of the earthing side looks fine, then look at the live side. You could have an internal break (pain in the arse, the wire looks fine but is broken inside the insulation), but if you are lucky you're find a wire which has chafed against something and is shorting out. Replace the offending section of wire.
5. If all of the earths look fine, and the wiring looks fine, and the relay is new, I would just replace the wires feeding the pump and see if that fixes it. So that's the live side to and from the relay, and the earth side from the pump.
Finally - make sure you know what voltage the pump is meant to have before you start fiddling with it. I have come across 9v fuel pumps on scooters before. I discovered it was a 9v pump after I put 12v across it and smoke came out.
Also, if all of this fails, it may work perfectly well on a gravity feed. A fuel pump on a carbed bike should only really be necessary when the fuel level in the tank is at or below the fuel level in the float bowls. This is only likely to be the last litre or two of reserve. |
WD Forte |
WD Forte World Chat Champion
adengtg |
Tdibs |
Tdibs Traffic Copper
andys675 |
andys675 World Chat Champion
Robby |
Robby Dirty Old Man
davebike |
davebike World Chat Champion
Posted: 09:51 - 14 Dec 2018 Post subject: |
Most fuel pumps act as a tap no power /no feed
drain carbs leave drain open turn in inigtion you should get fuel though if not
Check you have 12v to pump if not trace if yes you have a duff pump ! ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
bikenut |
bikenut World Chat Champion
The last post was made 5 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
