Are my bars bent?
evilzed
PostPosted: 18:00 - 09 Dec 2018    Post subject: Are my bars bent? Reply with quote
See pics here https://imgur.com/a/WLvViCA
So I had a low speed drop where my bike fell on the left side, the front didn't hit anything it was just a straight drop to the left side, the handle bars were locked to the left while it was down and the left bar end hit the ground.
So after the drop the bike feels like it steers ever so slightly to the right when going straight. Things I've tried
-Checking the bar risers for straightness with a straight edge installed and took them out to check the bolt sides and they were all straight as can be.
-Reinstalled the handlebars based on manual instructions to risers
-Loosening the entire front end clamp bolts etc including top yoke main nut and reinstalling the forks. The bike felt considerably better after doing this but still has slight off feeling
Looking at the bars sometimes they look bang on then other times they look crooked. I wanna avoid getting new bars if possible as the heated grips were just fitting and removing the clutch side glue and buying new bars etc only to find out they're straight would be annoying. Also getting the bar end thread adapter things out of these bars are almost impossible and cost £40 each from Yamaha
Thanks
Pete.
PostPosted: 18:12 - 09 Dec 2018    Post subject: Reply with quote
They probably are slightly bent. You would have felt it when you got back on though. Might be the forks are slightly twisted in the yokes too.
Stand the bike up straight and put a straight bit of wood along the wheels so they are in line. Now measure from the bar ends back to a point that's repeated each side, like a fairing bolt etc. If the bars are straight it'll measure the same both sides. Straightening them is easy, just a good tug in the right direction.
a.k.a 'Geri'
jaffa90
PostPosted: 18:16 - 09 Dec 2018    Post subject: Reply with quote
I would say twisted forks.
Riejufixing
PostPosted: 20:18 - 09 Dec 2018    Post subject: Re: Are my bars bent? Reply with quote
I am unsure how handlebars that are a tiny bit bent will cause this; after all, most people's arms are not precisely the same length, and one tends to "adjust" on the move.
Perhaps it's something else, e.g. as in the above psots, although the same applies?
evilzed
PostPosted: 20:40 - 09 Dec 2018    Post subject: Reply with quote
I already loosened both top and bottom yolks and reinstalled the forks to make sure everything lined up. Just wanted to see if anything looks out of line to others via the pictures.
@Pete yep as soon as I rode the bike after picking it up it felt like it was slightly bent. I might just deal with it for now as it's so minor.
talkToTheHat
PostPosted: 11:54 - 10 Dec 2018    Post subject: Reply with quote
Bent bars won't cause the bike to pull to one side. It might already have been pulling though due to tyre wear or a misaligned rear and you're only noticing now becasue you're looking for it.
Bandit. does. everything.
evilzed
PostPosted: 12:26 - 10 Dec 2018    Post subject: Reply with quote
There's absolutely no pulling the bike rides straight it's just the bars look ever so slightly and feel ever so slightly like they're a bit to the right while going straight that's all.
I just wanted to see if there's a way to diagnose bent bars before buying a new set etc I've loosened and checked over other variables already risers, yolks etc
Sister Sledge
PostPosted: 13:20 - 10 Dec 2018    Post subject: Reply with quote
Really difficult to explain in words but I'll try..
A fair but not precise way to diagnose bent handlebars is thus (Doesn't work with tapered bars - those with fatter centres where they clamp to the yoke) :
Remove the bars from the bike.
Remove every single fixture and clean them.
Find a perfectly flat surface that's raised off the ground a bit (easier to view).
Test flat surface with a long straight edge - a long spirit level should be good - a way to check straightness of the spirit level is to look along it from one end. By doing that you'll spot dips and uneven parts. Repeat the check at 90 degrees intervals along its length just in case.
OK so you have the flat surface. Place the bars down on it.
The test:
* Clamp section in the middle of the bars should be touching the flat surface its full central length or should be an even distance above that flat surface. If it's not then there's a bend wrong.
* If the central clamp section of the bars is touching its full length, what about both ends of the bars? If one is raised then there's bend wrong.
* If the ends and the central section is touching, measure what the raised 'elbow' parts are above the flat surface - this really is just approximation but it might also show issues.
* Flip the bars so that the ends are in the air and the opposite side of the central clamp section now touches the flat surface - you might have to physically load it down with a weight. Measure and look for irregularities/unevenness in those different locations: ends, elbows and most of all look for symmetry.
Remember to slide the bars around that flat surface and continue to check what touches - it simply confirms problems if seen.
Totally amateur but will give an indication of an obvious problem.
CCM 404 DS
The last post was made 5 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.74 - MySQL Queries: 17 - Page Size: 60.62 Kb
