bikenut |
bikenut World Chat Champion
bikenut |
Robby |
Robby Dirty Old Man
Posted: 18:02 - 18 Dec 2018 Post subject: |
The strange thing connected by some pipes to the inlet rubber and the exhaust (I think, hard to tell from the pics) should be a little air pump. They use inlet manifold pressure fluctuations to pump air into the exhaust, and make it appear to run a bit cleaner.
They aren't very effective at reducing emissions, they just disguise them a bit. They are prone to failure. Your bike will generally run a bit better if you remove the air valve and blank off its two holes (inlet and exhaust/cylinder head).
HT lead is just generic HT lead, unless yours is moulded into the coil. A new length of HT lead screws into the coil and the plug cap. Cost about £1/metre on ebay.
Valve clearances should be covered in the manual. Expect clearance to be around 0.1mm on both valves, sometimes a bit less for inlet and a bit more for exhaust. Rotate the engine to TDC using the inspection covers on the left hand side of the crank, check the clearances, adjust.
The air filter should not be dripping oil. To clean/reoil it:
1. Dip in petrol, squeeze out, dip, squeeze, repeat until you're happy its clean.
2. Let it dry.
3. Pour some engine oil onto it. Work it into the foam. Squeeze out the excess (hard squeeze). Refit, job done.
Sort out all of these service items and known problems before you try to hunt down any more problems and fix them. |
andy46 |
andy46 Derestricted Danger
DJMadness29 |
DJMadness29 L Plate Warrior
bikenut |
Posted: 11:09 - 20 Dec 2018 Post subject: 125 |
Cool, so the engine must have been a bit "tappetaby" then.
Start collecting bike tools for home. Take home expected tools needed for the service whilst on xmas break.
The chain needs to be just damp.
If its an o ring chain, then lubing is a bit difficult.
If its an ordinary chain, it can be removed, " boiled" in old engine oil which really helps with cleaning but don't do it in your kitchen!!
Use an old saucepan and camping stove outsidie but be very careful about burns and fires. A chip pan fire ( oil ) can be very serious and any water dropping into hot oil is literally "explosive", so be warned.
The hot oil removes the old lub, dirt and rust !
You will see the chain bubbling with small "squirts" of bubbles and even rust.
Allow to cool, then make sure every link articulates easily and freely, and ever roller rolls the same. I made a vice mounted level surface for the chain, wood long enough so the chain lies on its surface. I also use a strip of wood wide enough to fit between the plates and roll on the rollers.
Wear gloves.
I usually boil it twice and allow to cool enough, then take it out and allow to drip.
When ever link articulates and every roller rolls freely and smoothly, a i use a solvent and clean until the third filling stays clean. I use the old saucepan to clean the chain. When clean I hang the chain and allow to drip and dry.
Next I heat the chain in gear oil and watch the bubbles until they stop. The chain can be adjitate to free the bubbles. You could use linklife or similar.
Allow to cool enough the hang to drip.
An old chain is handy to feed onto the front sprocket when removing the bikes chain, and when refitting the serviced chain.
Wemoto do a good economy ordinary chain, swollow brand from memory, which seem good.
I also lube the front sprocket splines with molygrease.
Remember that the chain needs adjustment and be in correct tension when your weight is on the bike, and that the rear brake mechanism and rear brake light switch will need adjustment after the chain adjustment.
Rear brake working all ok, not stiff, releases properly and the mechanism is in proper "mechanical advantage" ?
You said the oil level seems to have risen ?
Cjheck for fuel in the oil by smell and the ease of which the oil "burns".
Dip the oil, then holding the dip stick with a drop of oil on its end, using a lighter, how easily does it burn ?
If it immediately burns then there is fuel in the oil. Is the dip stick plastic ? Dont burn the dip stick !
If it seems to burn immediately, immediately change the engine oil !!
Always when parked, turn the fuel off.
There may well be a tube on the bottom of the carb, a float chamber drain screw, and overflow. Any signs of the carb overflow overflowing ? ?
How many miles has this bike done ? ____________________ nuts about bikes |
The last post was made 5 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
