| Dtaylor12345 |
 Dtaylor12345 Two Stroke Sniffer
| Riejufixing |
 Riejufixing World Chat Champion
| Dtaylor12345 |
| Dtaylor12345 |
| P.addy |
 P.addy Red Rocket
| bikenut |
 bikenut World Chat Champion
 Posted: 15:07 - 12 Dec 2018 Post subject: sparocket |
mmmmmmmm this sprocket is "bolted" on and may also have a locking tab.
Please show the bolt and any washers that are to do with it.
There is some play there but usually that type of sprocket holding arrangement relies on a good fit between the sprocket and output shaft, else the bolt arrangement and locking devise can come loose due to drive and overrun forces.
Always grease those splines else they can corrode together making removal difficult and result in more play.
Since the bike is still under warranty, show the supplier and get their opinion.
Note, does the chain clear the raised portion of the sprocket, the chain plates should not be raised by the raised portion of the sprocket. Is the raised portion of the sprocket rubber, its not absolutely clear in the video......
and what bike is it please?
post a pic of the output shaft splines, any ridges/wear?? also when you removed the bolt, how tight was it, very tight, tight, or seemed a bit on the loose side for the application. ____________________ nuts about bikes |
| Dtaylor12345 |
| Dtaylor12345 |
| Dtaylor12345 |
| Dtaylor12345 |
| bikenut |
| bikenut |
| Dtaylor12345 |
| bikenut |
| Dtaylor12345 |
| Dtaylor12345 |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 17:40 - 12 Dec 2018 Post subject: |
Don't use copper grease, certainly not on a moving part. Copper grease is abrasive. Use LM based grease.
And the play in that sprocket is very normal, Loads of bikes are like this. Any tighter tolerances and you would struggle to slide on the new sprocket! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| dydey90 |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
 dydey90 World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 23:16 - 12 Dec 2018 Post subject: |
That movement is perfectly normal. Bolt it up and ride on. ____________________ a.k.a 'Geri'
| bikenut |
| MarJay |
 MarJay But it's British!
| P.addy |
 P.addy Red Rocket
| Dtaylor12345 |
| P.addy |
 P.addy Red Rocket
 Posted: 12:07 - 13 Dec 2018 Post subject: Re: wobble |
| MarJay |
The last post was made 7 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
