khanmurtaza |
khanmurtaza L Plate Warrior
Robby |
Robby Dirty Old Man
Posted: 13:41 - 24 Dec 2018 Post subject: |
My first thought is that this bike has been seriously mistreated in the past. Run for a long time with no servicing. Oil possibly topped up but not changed, plain tap water in the cooling system, that sort of thing.
Oil pressure first. I'm assuming the oil pressure light is occasionally coming on at idle revs when the engine is hot. If you're lucky, it means your oil pressure sensor is faulty - so change that first. If you're unlucky, it means your oil pump is faulty. If you're really unlucky, it means your crank is fucked.
You can bodge it to make the light go away by putting in some thicker oil, but it doesn't fix the problem. Fixing the problem is probably more than the bike is worth.
Coolant temperature next. Working on the basis that the bike has been neglected in the past, I would expect the engine and radiator to be plugged up with shit inside and out.
Take the radiator off the bike, clean it, straighten out the fins if they are bent so air can go through it. Then flush it through with a garden hose. If a lot of crap comes out of it, that's a good thing - it means its getting better. I tend to flush both ways, at least 5 minutes in each direction.
Flush the engine too, in the same way. You may need to remove the thermostat for this to work.
Finish by putting it all back together and filling up with the right mix of coolant, and bleeding.
On the neglect theme, it never hurts to change the spark plugs. If they have been in there for years, they could be totally worn out, to the point of ceramic insulation breaking off inside the combustion chamber. That's not something you want to happen.
Finally, this is a UK based forum, so no need to quote Fahrenheit. |
chris-red |
chris-red |
khanmurtaza |
khanmurtaza |
Posted: 00:10 - 03 Jan 2019 Post subject: |
Robby wrote: | My first thought is that this bike has been seriously mistreated in the past. Run for a long time with no servicing. Oil possibly topped up but not changed, plain tap water in the cooling system, that sort of thing.
Thanks for your detailed reply robby. It may have been treated badly but since I have owned it for over a year now I have only probably ridden it 2000 miles and have already changes oil, filter, and coolant atleast twice. So it only happened once around six months after I purchased it then went away but now even at operating temperature and at slightly higher revs oil light (red) and the other oil warning blinking is carrying on. I have not taken it out on the road since this issue to avoid further damage. I have add thicker oil already to avoid funny idling at high temps but nothing changed.
I have not changed the spark plugs as the last time I tried to upgrade to iridium the bike was seriously misfiring, maybe just a faulty plug. Plugs looked fine about 1000 miles ago but I can change them. Will also try the radiator flush and clean if this oil issue gets sorted.
Gutted as I really love the ride. I have ridden a lot of bikes but love the way it handles.
So a million $ question is, shall I try and change the pump and sensor see what happens? I was hoping that its the pump as I have heard that faulty pump also exacerbates the hot running of a bike? ____________________ Murtaza (super sports, sports touring and cruisers) |
khanmurtaza |
khanmurtaza |
Robby |
Robby Dirty Old Man
The last post was made 5 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
