| Author |
| Sub_Steppa367 |
 Sub_Steppa367 L Plate Warrior
| Back to top |
| jaffa90 |
 jaffa90 World Chat Champion
| Back to top |
| Sub_Steppa367 |
| Back to top |
| Nobby the Bastard |
| Back to top |
| bikenut |
 bikenut World Chat Champion
| Back to top |
| Sub_Steppa367 |
 Posted: 14:22 - 31 Dec 2018 Post subject: Re: cbr125 |
| bikenut wrote: | visit cmsnl and find your bike. I could not find a 2012 model so looked at the 2011 uk one.
It has an electronic speedo with a dog driven sensor at the wheel, very similar to a cable driven type, but not identical.
A dog drive plate is there which, if the wheel is not correctly fitted etc. can bend the dogs on the dog rive plate.
This could cause this problem as well as damage the actual sensor, but your suggests a bad connection in the system.
Does the neutral light misbeahave, or any other lights misbehave when the handle bars are turned from lock to lock??
The wire from the sensor up to the instruments has to flex due to the suspension movement, an ideal fatique and make and break bad connection, so test that as well. |
I've tested moving the bars today and had no problems with any other signals on the dash, indicator lights,full and dipped beams, neutral light etc. There is a lot of slack in the cable running from the sensor so I don't think it's tugging and coming loose either. I've given the cables running in to the back of the dash a slight push, they're a little wobbly but not to much. I've got a gps so I'm going to take it out for ten minutes to see of that's helped.
If not I imagine it's the sensor that's bust. Thanks for you help! |
| Back to top |
| bikenut |
| Back to top |
The last post was made 7 years, 274 days ago. Instead of replying here, would creating a new thread be more useful? |
