laurence231 |
laurence231 Derestricted Danger
Posted: 07:52 - 02 Jan 2019 Post subject: HONDA CBR125 06: Bike only runs on choke |
Hello!
(apologies if post is duplicate - posted last night but it hasn't appeared here!)
I recently bought a 2006 CBR125 a couple of weeks ago as my first bike, working but quite cheap so was expecting issues to work on as time went on. The choke cable turned out to be siezed in the carb, so I recently replaced all the slider/spring and cable (I had to buy a spare carb as it was cheaper than just buying the slider/spring from a dealer who wanted £90 for a brass slider and spring!)
My latest problem, now I have fixed this is that the bike runs great when starting (air filter replaced too btw) with the choke on, but the moment that I put the choke off, the bike cuts out (even after a long ish ride with the choke part open).
From some research online, apparently its most likely cause is that a pilot jet in the carb is blocked/clogged, and carb should be disassembled and cleaned. At the same time, as a beginner to mechanical work, carb dissasembly seems a lot of work at best, and risky too. Should I try spraying some sort of carb cleaner down fuel pipe to try and clean the inside of the carb? Something like seafoam which I see mentioned a lot? Or should I not delay the inevitable and just disassemble and clean the carb? (I have a spare carb to practise on thanks to buying another carb to fix the choke assembly).
Apparently another alternative might be some sort of air leak although I imagine this is less likely. Anyone have any advice for me at this stage as to how I should proceed?[/b] |
Meatybeaty |
Meatybeaty World Chat Champion
laurence231 |
Meatybeaty |
bikenut |
bikenut World Chat Champion
laurence231 |
Meatybeaty |
laurence231 |
Posted: 17:00 - 04 Jan 2019 Post subject: |
Meatybeaty wrote: | The idle screw will only adjust the accelerator stop, could be that its wound out too far , this is the adjuster number 5 in the picture, found on the righthand side of the carb |
Thanks for the help! Here's what happened when I adjusted the idle -
I can get it so that with choke cable fully opened, the bike would idle at about 2500-3000. I can then close the choke, and the bike will go down to perhaps 1300 and drop to 900 ish then cut out shortly after. I set the idle speed even higher than that, and then with choke fully opened, the bike idles at 2500, slowly rises to 3000 and then absolutely flies up to 5000 rpm, when i slammed the choke down it goes down to about 1300, and does the same as before where it slowly diminishes until it cuts out.
So whilst this is definitely the right route, there does seem to be some other issue. Any ideas on what it might be? Could a carb clean be in order? Or could it be something else?
Also -
another interesting observation - when the engine starts it sometimes idles a little higher (by about 500 rpm) more than it eventually settles down to - is this normal? In general, there is some fluctuation in idle speeds |
Nobby the Bastard |
laurence231 |
Meatybeaty |
Tankie |
Tankie Crazy Courier
Nobby the Bastard |
Grubscrew |
Grubscrew Scooby Slapper
laurence231 |
jaffa90 |
jaffa90 World Chat Champion
Posted: 00:31 - 05 Jan 2019 Post subject: |
As Tankie suggests. |
laurence231 |
Posted: 18:18 - 06 Jan 2019 Post subject: |
Thank you to you all for your help!
I appear to have resolved the issue (at least for now). I replaced the spark plug with a fresh one and the new one seems to work better. I am sure the idle jet still has issues, as there is some fluctuation in idle rpm, however the bike starts and idles well and hasn't cut out yet, with the choke off
Now the bike shouldn't be running so rich permanently, hopefully its a lot longer before this spark plug gets ruined! Will update here if any more issues arise. |
The last post was made 5 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
