Holadog |
Holadog L Plate Warrior
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 17:53 - 09 Jan 2019 Post subject: |
Why would you want to?
AFAIK most of the small honda's share a common bolt-pattern, derived from the original OHC single used in the, CB/SL 125 single of the early '70's that went on to be evolved into the OHC lump used in the, oooh... XL125, CB100, CB125RS, and many others.
The CB125 'twin' was derived of that motor, and shares frame mounts, as was the push-rod CG engine, retro-engineered for lower maintenance (and performance... sort of an engineering limbo exercise), for developing country markets to compete with the vertially no-maintenance two-smokes.
So, a CG motor 'aught' drop into an early XL frame, bolt-for-bolt, easy as pie.... it's pretty much what Honda did to make the later XR125 road bike....
Problems, might arise around the exhaust and carb/air-box, but most head scratching will likely be found trying to match the electrics.
Old XL125 was 6v points, later model CG's were 12v CDI ignition. Some ingenuity will likely be required to match the wrigglies and make stuff work.
Plenty of bits available on the bay and in the scrap-yards, and plenty of interchangeability, its eminantly do-able... but not necesserily the most easy... and btt... other than CG's and clones being three a penny, why would you want to degrade an EX that probably had around 12bhp, with a motor that at best, likely only makes about 10?.
There's some sense in doing it for an every-day rider, to make it that bit more every-day maintainable with more easily obtained bits.... but as a genuine forty odd year old classic? Turning it into a hybrid would rather throw away much of its classic worth and value, as well as oomph... and 20% on a bike that struggles to NSL is a lot to sacrifice...
But, your call. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Nobby the Bastard |
WD Forte |
WD Forte World Chat Champion
blurredman |
Posted: 10:53 - 10 Jan 2019 Post subject: |
I had an XL125 from 1978. Which had a same period CG engine put in it. Either that or the electrics were swapped back over for 6v. Anyway.. The only problem was lack of 6th gear that the XL125's have meant it barely topped at 50mph. I didn't think much of it. I presumed someone had blown the original engine up in the past. Which wasn't a surprise given it was such an old '125'. As I could see, the mounting locations were identical.
This is a picture of what I had.
https://cloud.leparking-moto.fr/2018/04/26/02/55/honda-xl-honda-xl-125-s-1983-moto-e-scooter-usato-in-vendita-pesaro-e-urbino_86761663.jpg ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (bored to 295cc) - 38k, 1990 MZ ETZ251 - 49k, 1979 Suzuki TS185ER - 9k, 1973 MZ ES250/2 - 17k. |
bladerunner |
Posted: 00:28 - 12 Jan 2019 Post subject: |
wont notice much difference between 12 and 10hp....you'll bloody well notice a 20% drop in power for sure but then again I suppose you can drop a 160cc kit and carb on the CG motor and all is good with forward progress again ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
steve the grease |
terrytibbs |
terrytibbs Derestricted Danger
Posted: 17:57 - 20 Jan 2019 Post subject: |
Teflon-Mike wrote: |
..but as a genuine forty odd year old classic? Turning it into a hybrid would rather throw away much of its classic worth and value, |
Do you ever read what you type before posting or are you too busy trying to sound self important? To spell it out for you, if it's a bolt in swap it can be un-bolted can't it
No it doesn't, ever tried It? Rear crank case mounts are wider by a fair margin |
The last post was made 5 years, 90 days ago. Instead of replying here, would creating a new thread be more useful? |
