Yamaha YBR 125 - Service management light
JamesDuncann
PostPosted: 08:50 - 11 Jan 2019    Post subject: Yamaha YBR 125 - Service management light Reply with quote
Morning all, I’m having issues with the trusty YBR this time the service light is coming on but I am unable to see the flashing quick enough when it happens to then understand the fault codes.
It seems to be happening after I have set off from a traffic light and apply more throttle or if I speed up quickly from a slow pace.
Would make sense to be something to do with the throttle as that is the only thing I have messed about with changing the cables since I had the bike.
Any help?
Regards
James
PostPosted: 09:38 - 11 Jan 2019    Post subject: Reply with quote
Probably needs the Throttle Position Sensor resetting.
cb1rocket
PostPosted: 15:57 - 11 Jan 2019    Post subject: Reply with quote
loose battery terminals
JamesDuncann
PostPosted: 15:16 - 20 Jan 2019    Post subject: Reply with quote
Could this also be a side stand switch fault, if so what am I looking for?
Edit:
I think this was the problem as the switch seems loose and the sensor can swing about a little.
The bolt is rounded off though, will I have to drill this out and replace the bolt?
If so, could someone tell me if number 26 is the correct bolt?
https://www.fowlersparts.co.uk/parts/5452234/ybr125ed-2012-51d2-europe-black-metallic-x/electrical-1
Thanks in advance.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:29 - 20 Jan 2019    Post subject: Reply with quote
Ffs just bypass the switch.
Triumph Sprint ST 1050
The last post was made 7 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.64 - MySQL Queries: 14 - Page Size: 43.25 Kb
