Pictures of my Ducati Winter build 2019/20
 Topic moved: from The Workshop to Show & Tell by stinkwheel (26 Jan 2020 - 13:20)
buzzer1955
PostPosted: 09:31 - 13 Jan 2019    Post subject: Pictures of my Ducati Winter build 2019/20 Reply with quote
Hi guys. First post here...
Every winter i do a project, sometimes a car, but for the last few years a bike. This year its been a Ducati, same as last year, and the year before it was a Suzuki.
So my thoughts are turning to the next project... which i want to be a scrambler style bike. With that in mind, i will be looking for a donor, so i am looking for suggestions and insparation!
The criteria is...
Air cooled
Spoked wheels
500cc or bigger
Must have a strong reliable engine
Budget of about £2000
Any suggestions?
Robby
Dirty Old Man
PostPosted: 14:26 - 13 Jan 2019    Post subject: Reply with quote
XL600R ticks your boxes.
There is a gap of 1 year, 12 days between these two posts...
buzzer1955
PostPosted: 12:00 - 26 Jan 2020    Post subject: Reply with quote
Well I missed all but one of my criteria... Only managed to get below £2000... here are a few photos that tell the story of this winters build...
https://jtccc.files.wordpress.com/2019/02/aadsc01482.jpg
https://jtccc.files.wordpress.com/2019/03/33391376238_fe6f919109_o.jpg
https://jtccc.files.wordpress.com/2019/04/manifold-1.jpg
https://jtccc.files.wordpress.com/2019/08/tank-fab.jpg
https://jtccc.files.wordpress.com/2019/09/brracket-die.jpg
https://jtccc.files.wordpress.com/2019/11/crack-2.jpg
https://jtccc.files.wordpress.com/2019/11/ducati-996-engine-paint-1.jpg
https://jtccc.files.wordpress.com/2019/11/diy-plating-3.jpg
https://jtccc.files.wordpress.com/2019/11/finished-zinc-plating.jpg
https://jtccc.files.wordpress.com/2019/11/top-yoke.jpg
https://jtccc.files.wordpress.com/2019/12/frame-on-engine-3-small.jpg
https://jtccc.files.wordpress.com/2019/12/img_0894-copy.jpg
https://jtccc.files.wordpress.com/2019/12/49187760423_b63409eb06_o-copy.jpg
https://jtccc.files.wordpress.com/2019/12/side-1-copy.jpg
https://jtccc.files.wordpress.com/2019/12/leads.jpg
https://jtccc.files.wordpress.com/2019/12/wiring-1.jpg
PostPosted: 14:20 - 26 Jan 2020    Post subject: Reply with quote
I'm going to move this to Show and Tell so it doesn't drop off the bottom so quickly.
You might want to edit the title of the original post so people can see what the project is?
I like your mudguard bracket mandrel. Wish I had the machining expertise to make stuff like that. I landed up brazing tabs onto mine.
buzzer1955
PostPosted: 14:58 - 26 Jan 2020    Post subject: Reply with quote
thanks, I have edited the title now...
here is a video of it running!
https://www.youtube.com/watch?v=t_zGWiIyVQs
PostPosted: 15:17 - 26 Jan 2020    Post subject: Reply with quote
Loving the birds-nest on the floor in this picture:
Did you buy a used car loom or is that what you ripped out of the bike? Car loom is a good way to get lots of different colour wires cheaply.
What's the little PCB with the LED readout on it?
buzzer1955
PostPosted: 15:14 - 27 Jan 2020    Post subject: Reply with quote
yes, I went to the scrap yard and got some bits of car loom for the wire, its a good source...
the digital readout is for the fan... The fan was originally switched by the old ECU but the new ignition does not have that function... this is a cheap and easy way around it, the little unit is less than £5 and they are quite reliable and can be set to switch at any temperature. the temp probe fits in the original sensor plug with some araldite... the unit is now in a little plastic box...
I like to draw the circuits of the wiring as I do it, and write the colours on the print out as I go along... nice to give any new owner some help for the future, otherwise it would be a nightmare to fault Mr. Green
https://jtccc.files.wordpress.com/2019/12/sense-1.jpg
https://jtccc.files.wordpress.com/2019/12/fan-wire.jpg
https://jtccc.files.wordpress.com/2019/12/wire-3.jpg
buzzer1955
PostPosted: 20:58 - 30 Jan 2020    Post subject: Reply with quote
Spent a couple of hours making a chain guard today… should keep the MOT man happy. He follows my builds, and sometimes messages me to say he will fail it!
https://jtccc.files.wordpress.com/2020/01/chain-small.jpg
Pete.
PostPosted: 23:44 - 30 Jan 2020    Post subject: Reply with quote
That's simply awesome Tony, I have a ton of questions and every time I look at the pics another one pops up.
Love the DIY plating setup. What is it copper then zinc? Did you have any trouble with the spindle diameters growing?
Did you roll the cones for the cans yourself? They look very neat.
What happened to the lobster-back ends on the cans? Change your mind?
Carbs from what?
Can't place the lathe. Looks very "South-bend 9 clone" but the countershaft tensioner lever I can't place that at all. Early non-underdrive Boxford? I love that you're using the original rocker post, I wouldn't have the patience for that.
Frustratingly, I can't place that bench-top milling-machine with the funky jig-bore-style sliding head either.
How many times did you have to go round the tank to get all the pin-holes?
Totally inspirational really. I'd like to see much more.
a.k.a 'Geri'
buzzer1955
PostPosted: 12:48 - 31 Jan 2020    Post subject: Reply with quote
Thanks Pete!
the plating came out well... it was a zinc kit and I did the blue pasivate to get the bright colour. its microns thick, so there were no problems with threads and spindles.
to roll a cone is very difficult... I bought the silencers with the lobster back quite cheaply (£20 each) off ebay... and cut the ends off and used the front cones, and made the end cone. I can pop some restrictive baffles in there to keep the mot man happy.
The carbs ar 48 mm CV off a honda VTR... the biggest cards fitted to any bike I could find... the original throttle bodies were 50mm so they should be OK....
The lathe is a Boxford... I bought it 40 years ago... it came with lots of tooling, and imperial and metric change wheels which I still have, and even the original handbook with the commissioning installers sheet, all filled in! its a lovely machine
the milling machine is VERY old, there is no name on it, but it dates from the early 30's. again its a robust machine. Last year I replaced it... with a Clarke machine. it lasted a week, it was pathetic compared to the one you see in the pictures. I quickly sold it and went back to the old one!
as for welding the tank... I had two leaks... I use a dye penetrant kit which is brilliant! spray on the dye, leave for a min, and then spray the developer on there. any leaks show immediately. you then spray on a cleaner, and weld up the leak. picture below. I have made a couple of alloy tanks in the past, but used fibreglass covers on them.
https://jtccc.wordpress.com
you can always look at my blog, link above, if you want to see more....
https://jtccc.files.wordpress.com/2019/08/leak-detection.jpg
https://jtccc.files.wordpress.com/2015/11/tank-14.jpg
https://jtccc.files.wordpress.com/2015/11/tank-16.jpg
https://jtccc.files.wordpress.com/2015/11/tank-stree-1.jpg
https://jtccc.files.wordpress.com/2015/11/tank-styree-3.jpg
https://jtccc.files.wordpress.com/2015/11/suzuki-gt500-t500-cafe-racer-2.jpg
[img][/img]
PostPosted: 15:26 - 31 Jan 2020    Post subject: Reply with quote
Nice! Love the leak-dye idea Thumbs Up
Pete.
PostPosted: 19:08 - 31 Jan 2020    Post subject: Reply with quote
Dye penetrant is crack-testing gear. Works for leaks too I see. I usually plug all the holes and put 5psi in the tank then spray all the welds with leak detector. If there's a pin hole it blows bubbles. The only trouble is my cheapo pressure regulator knob goes slack when there's no pressure to it, so it adjusted itself when disconnected and next time I used it I put 30psi into a tank, and this happened Very Happy
(these two tanks are supposed to be the same size)
a.k.a 'Geri'
PostPosted: 19:56 - 31 Jan 2020    Post subject: Reply with quote
"This one weird trick will increase the range of your bike!!!"
buzzer1955
PostPosted: 11:48 - 01 Feb 2020    Post subject: Reply with quote
to be honest, I do the same... but I have a hand pump that I use to put some pressure in the tank, and then spray some weak fairy liquid mixture on the joints as a last check before painting... I dont use fuel as if there is a leak, its a real pain to get the fuel out... if i HAVE to weld a tank that's recently had fuel in it, I fill it with CO2 from a fire extinguisher before getting any where near it with a torch!
It can also be very dangerous to pressurise weak tanks..., like a bike petrol tank...
Back in the old days we used to underseal cars, the underseal came in 5 gallon steel drums... One day the apprentice coupled up a new drum to the spray gun, but got the hoses mixed up, and pressurised the drum! luckily he walked away a few paces before the container exploded! he was fortunate in that the seam of the drum was faceing away from him because the blast seriously dented both doors on a car!
There is a reason we have pressure vessel regulations...
you can imagine the cleanup we had to do in a dealership workshop after that!
PostPosted: 14:45 - 01 Feb 2020    Post subject: Reply with quote
The "one weird trick" I do know for tanks that have recently had fuel in: pipe the exhaust from a car into the tank and that purges all the petroleum fumes out after running for a bit.
Pete.
PostPosted: 15:22 - 01 Feb 2020    Post subject: Reply with quote
Not as safe as you might think. Car exhaust fumes can be combustible. The biggest benefit of doing it is that the heat of the exhaust fumes will cause the residual fuel to evaporate quickly and the volume of fumes will carry the evaporations away.
a.k.a 'Geri'
PostPosted: 18:00 - 01 Feb 2020    Post subject: Reply with quote
Dammit, I get educated every day on here Laughing
buzzer1955
PostPosted: 20:19 - 01 Feb 2020    Post subject: Reply with quote
well thanks to a member on the Ducati Custom manufactures group mentioning a case saver, I have now made one out of stainless steel and put it under the chain guard I have made. a bit of googling suggests that chain breakages, and subsequent case damage is all too common on some Ducati bikes! Plenty of case savers on the market and quite cheap, and a dam site cheaper than new cases!
Also made a start on the tank and seat... my wife is moaning about filler dust on her plants Embarassed Embarassed ! A trick I learned many years ago is that when you want to get filler to shape, make sharp edges so you can see the lines, then when you are satisfied they are right, sand them off! its much easier that way. its the best way to get something like a car wheel arch spot on… I know the seat will divide opinion… I could have made it any shape, and played around with quite a few shapes at the foam stage… but in the end I decided on this on, as I like it, and that’s all that matters at the end of the day, I build bikes for me!
https://jtccc.files.wordpress.com/2020/02/chain-3-copy.jpg
https://jtccc.files.wordpress.com/2020/02/seat-1-copy.jpg
https://jtccc.files.wordpress.com/2020/02/seat-3-copy.jpg
https://jtccc.files.wordpress.com/2020/02/tank-2-copy.jpg
https://jtccc.files.wordpress.com/2020/02/tank-1-copy.jpg
PostPosted: 20:26 - 01 Feb 2020    Post subject: Reply with quote
Very impressed. Only wish I had the skills and the necessary commitment...
BTW T500 Suzuki? Did you make the expansions??
buzzer1955
PostPosted: 20:45 - 01 Feb 2020    Post subject: Reply with quote
no, I was very lucky... I found a pair at a local shop of all places! just word of mouth that I was looking for some expansion boxes... the guy had them in stock, but they had been modified for a bike, which was not a problem to me...
dekip
PostPosted: 22:39 - 01 Feb 2020    Post subject: Reply with quote
Great, man.
As a electronics/programmer geek, i like the use of thermocouple. These cold joints makes me crazy these days as i am in designing custom board for high temperature measuring. Eventually, it works. Smile
Long time reviewer in computer magazine.
That include all wireless devices, SBC and microcontrollers. When my brain get stuck, all that helps is ride.
My bikes: MZ 175SE (1967), Yamaha Virago XV535 (1993) and TVS Apache (2008)
buzzer1955
PostPosted: 10:50 - 06 Feb 2020    Post subject: Reply with quote
Well here it is in primer... just got to decide on colour now... I have plenty of time to think about it, this will be the last update for a while... I am being kidnapped and sent to a tiny (and I mean tiny!) island where there are no cars, bikes, transport, just beaches... and sun... and no internet. Quite frankly, I don't know how I am going to cope Shocked
https://jtccc.files.wordpress.com/2020/02/primer-small.jpg
PostPosted: 12:16 - 06 Feb 2020    Post subject: Reply with quote
Maybe these would be of help:
https://i.imgur.com/3gD8m0b.jpg
https://i.imgur.com/kRVilkU.jpg
https://i.imgur.com/Gd6AAB8.jpg
https://i.imgur.com/HJ9ZfPJ.jpg
https://i.imgur.com/Tz06z5J.jpg
https://i.imgur.com/R2kZl8R.jpg
https://i.imgur.com/DLDGarJ.jpg
https://i.imgur.com/UtAPCzS.jpg
PostPosted: 16:07 - 06 Feb 2020    Post subject: Reply with quote
Red ones go faster. Well known fact.
buzzer1955
PostPosted: 18:54 - 06 Feb 2020    Post subject: Reply with quote
Easy-X that's brilliant! Thank You!! i like several... I am going to ponder while we are away...
The last post was made 6 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.13 - MySQL Queries: 16 - Page Size: 140.78 Kb
